| thomasotten |
Mar 10 2025, 09:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,592 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I have determined that the shroud on my 914-6 core is incorrect. I need the shroud that has the long ducting to the oil cooler. Anyone have the proper shroud? I also need the right side ducting next to the fan. Thanks
| Montreal914 |
Mar 10 2025, 11:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
@mb911 Ben should have the engine tin, if I understood correctly what you are looking for.
EDIT: Looks like I didn't get this right... Well if you also need the perimeter tin, Ben got you covered. As for the triangular piece next to the fan, I am going through this miself. Will you have heat hexchangers or going with headers with no heat? That triangular piece would be different depending on this. |
| thomasotten |
Mar 11 2025, 04:00 AM
I have the surrounding tin. I just need the piece to the right of the fan, the stock piece, not a block off plate. Also, if someone has the correct 914-6 shroud.
| sixaddict |
Mar 11 2025, 05:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,097 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Source available that makes new……my shroud was ok but I needed the light gray duct piece. He can do both …..
I think he goes by Series 9…… Nice product in my experience I will check and advise if Series 9 isn’t correct. |
| sixaddict |
Mar 11 2025, 05:25 AM
| sixaddict |
Mar 11 2025, 05:41 AM
Correction
Series 900 |
| sixaddict |
Mar 11 2025, 05:48 AM
| thomasotten |
Mar 11 2025, 07:00 AM
Yes I need the whole assembly including plate and plastic duct
| sixaddict |
Mar 11 2025, 08:17 AM
So I have #6 newly powder coated satin black
# 7 available new #5 I do not have. Suspect best to see if you can land the whole package. Good luck Sorry about trip on Series 900 shroud…..misunderstood your question. |
| gereed75 |
Mar 11 2025, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
I may have a spare #5.
I am away from my stash and will not be home until mid April. If you can’t find one remind me then and I will search my stuff. Also check withKarl Hens at Thouroughbred Motorsports up in Corey PA. He has A LOT of stuff! |
| mlindner |
Mar 11 2025, 12:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,808 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
You can just buy an addition air scoop that runs from your shroud to the cooler. Just cut a hole and rivet on. I have pictures of mine somewhere, I'll look for them. Mark
| mlindner |
Mar 11 2025, 01:05 PM
| MasterCylinder |
Mar 11 2025, 07:09 PM
Newbie ![]() Group: Members Posts: 11 Joined: 5-November 15 From: California Member No.: 19,335 Region Association: Southern California |
I have these four parts. Was told it’s a 2.2T shroud so it should be the same as a 914-6.
| thomasotten |
Mar 12 2025, 12:59 AM
| MasterCylinder |
Mar 12 2025, 01:25 PM
Wow, for a newbie to the forum you have EXACTLY what I need! I have these four parts. Was told it’s a 2.2T shroud so it should be the same as a 914-6. ![]() I Have no idea what they are worth. Perhaps somebody could advise James |
| sixaddict |
Mar 12 2025, 01:47 PM
Series 900 makes the two FG parts……I think the black one is $450 but going by memory which is faulty. I can’t recall what the light gray one is but check and that can give you an idea….
Also package of most of the parts would be helpful …..so that becomes a value added. Just saying |
| dug |
Mar 12 2025, 02:08 PM
914-6 conv in progress ![]() ![]() Group: Members Posts: 186 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
I have a very nice 914-6 shroud. I'll post a pic later this evening.
| MasterCylinder |
Mar 13 2025, 03:42 PM
PM Sent
James |
Lo-Fi Version | Time is now: 9th November 2026 - 08:47 AM |
