thomasotten
Mar 10 2025, 09:32 PM
I have determined that the shroud on my 914-6 core is incorrect. I need the shroud that has the long ducting to the oil cooler. Anyone have the proper shroud? I also need the right side ducting next to the fan. Thanks
Mar 10 2025, 11:11 PM
@mb911 Ben should have the engine tin, if I understood correctly what you are looking for.
EDIT: Looks like I didn't get this right... Well if you also need the perimeter tin, Ben got you covered.As for the triangular piece next to the fan, I am going through this miself. Will you have heat hexchangers or going with headers with no heat? That triangular piece would be different depending on this.
thomasotten
Mar 11 2025, 04:00 AM
I have the surrounding tin. I just need the piece to the right of the fan, the stock piece, not a block off plate. Also, if someone has the correct 914-6 shroud.
sixaddict
Mar 11 2025, 05:17 AM
Source available that makes new……my shroud was ok but I needed the light gray duct piece. He can do both …..
I think he goes by Series 9……
Nice product in my experience
I will check and advise if Series 9 isn’t correct.
sixaddict
Mar 11 2025, 05:25 AM
Click to view attachment I may have an extra one of these….if you need. There is also a plate and plastic duct that goes there. Plate is available new.
Others helped me get this right so I’m just paying it forward…..thanks to them.
sixaddict
Mar 11 2025, 05:41 AM
Correction
Series 900
sixaddict
Mar 11 2025, 05:48 AM
Hope this is what you are needing
thomasotten
Mar 11 2025, 07:00 AM
Yes I need the whole assembly including plate and plastic duct
sixaddict
Mar 11 2025, 08:17 AM
So I have #6 newly powder coated satin black
# 7 available new
#5 I do not have.
Suspect best to see if you can land the whole package.
Good luck
Sorry about trip on Series 900 shroud…..misunderstood your question.
gereed75
Mar 11 2025, 10:45 AM
I may have a spare #5.
I am away from my stash and will not be home until mid April. If you can’t find one remind me then and I will search my stuff.
Also check withKarl Hens at Thouroughbred Motorsports up in Corey PA. He has A LOT of stuff!
mlindner
Mar 11 2025, 12:59 PM
You can just buy an addition air scoop that runs from your shroud to the cooler. Just cut a hole and rivet on. I have pictures of mine somewhere, I'll look for them. Mark
mlindner
Mar 11 2025, 01:05 PM
Found this one. The long black object from the cooler up to back of shroud. Mark
MasterCylinder
Mar 11 2025, 07:09 PM
I have these four parts. Was told it’s a 2.2T shroud so it should be the same as a 914-6.
thomasotten
Mar 12 2025, 12:59 AM
Wow, for a newbie to the forum you have EXACTLY what I need!
QUOTE(MasterCylinder @ Mar 11 2025, 05:09 PM)
MasterCylinder
Mar 12 2025, 01:25 PM
QUOTE(thomasotten @ Mar 11 2025, 10:59 PM)
Click to view attachmentI Have no idea what they are worth. Perhaps somebody could advise
James
sixaddict
Mar 12 2025, 01:47 PM
Series 900 makes the two FG parts……I think the black one is $450 but going by memory which is faulty. I can’t recall what the light gray one is but check and that can give you an idea….
Also package of most of the parts would be helpful …..so that becomes a value added.
Just saying
dug
Mar 12 2025, 02:08 PM
I have a very nice 914-6 shroud. I'll post a pic later this evening.
MasterCylinder
Mar 13 2025, 03:42 PM
PM Sent
James
click here.
