| andrewvolsen |
Oct 16 2026, 01:32 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I acquired a fairly large haul of 914 parts last night in preparation for my next 914 project car. Today I started sorting through the first truck load of it, and I could use some help identifying a few items.
I believe these are factory front sway bars, correct? Attached thumbnail(s) |
| andrewvolsen |
Oct 16 2026, 01:34 PM
I think the top sway bar is a factory rear sway bar, but I'm not sure about the other two. Any suggestions?
| andrewvolsen |
Oct 16 2026, 01:49 PM
914 struts with rotors modified for studs in a 5 lug pattern?
| andrewvolsen |
Oct 16 2026, 01:52 PM
Early 911 Boge strut housings?
| andrewvolsen |
Oct 16 2026, 02:00 PM
Later 911 strut assemblies (SC or Carrera)?
| andrewvolsen |
Oct 16 2026, 02:20 PM
Rear trailing arms with 914 hubs drilled for 5 lug bolts. Does anyone recognize what the brake calipers and vented rotors are from?
| Luke M |
Oct 16 2026, 03:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,616 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Looks like you have all front factory sway bars (16 mm) . 1 factory rear sway bar ( the one with the ball ends ) , the other 2 are weltmeister rear 914 sway bars.
The front struts you can look up the part #'s and it should say what they go to. The rear 914 parts look like a hybrid of 914 and 911 parts. brakes are 911 but hubs look to be 914 modified to 5 lug but using bolts? |
Oct 16 2026, 03:39 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,946 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap.
| andrewvolsen |
Oct 16 2026, 06:04 PM
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap. I hit them with some scotchbrite and water and they seemed to clean up ok. I don't have any wheel bearings on hand to check if the inner races still fit tightly, though. Attached thumbnail(s) |
Oct 16 2026, 08:09 PM
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap. I hit them with some scotchbrite and water and they seemed to clean up ok. I don't have any wheel bearings on hand to check if the inner races still fit tightly, though. Not ok enough for a bearing surface. |
| dtmehall |
Oct 16 2026, 08:34 PM
Member ![]() ![]() Group: Members Posts: 385 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| andrewvolsen |
Oct 16 2026, 09:44 PM
The bearing rollers don't run on that surface, it just carries the inner bearings races
| Montreal914 |
Oct 17 2026, 06:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,210 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
In your first picture with the front sway bars. Maybe it’s picture distortion but are the drop links longer on the one on the right? If so the links would be 911. 914 bar should be 15mm. You should see 15 stamped at the end on the square face. I think 911 bars are 16mm.
Your rear trailing arms have been fitted with 911 rear vented rotors. The hubs are therefore 5 lugs which could be different things, drilled 914, 914-6, 911, or other Porsche hubs. The calipers seemed to be rear 911. This probably means you do not have an E-brake unless the 911 inner drum brake was retrofitted. |
| iankarr |
Oct 18 2026, 12:57 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
The strut assembiies which accept a pinch bolt are early. Later ones took a wedge pin.
| rjames |
Oct 18 2026, 10:38 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,482 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
The spindles on the front struts are so rusty, they are trash. They have bearing surfaces in them that are ruined by the corrosion. Other than the sway bars and maybe the front 911 hubs, the rest looks to be scrap. I hit them with some scotchbrite and water and they seemed to clean up ok. I don't have any wheel bearings on hand to check if the inner races still fit tightly, though. Not ok enough for a bearing surface. I also agree that the hearing surfaces probably aren’t in spec anymore. |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:35 AM |
