| NARP74 |
Aug 6 2026, 05:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT... I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection. I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask! Is there a torque spec for that nut other than the typical German phrase? |
Aug 6 2026, 06:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,981 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
For what it’s worth it’s supposed to be a fiber washer not a copper washer.
Hope you can get er’ done without pulling the tank. |
| NARP74 |
Aug 6 2026, 08:23 PM
Well copper is what came with the new sock I ordered. Hmmm, more bad luck.
Lo-Fi Version | Time is now: 6th August 2026 - 10:05 PM |
