> Small Electrical Connectors, Needed for Project
NARP74
post Aug 3 2026, 04:11 PM
When I took my turn signal switch out to replace it, I had some wires that came out with it. Looks like the washer switch has been upgraded to an electrical type pump. The wires were unterminated. I need some small connectors to go though the steering housing so I can disconnect them the next time I have to replace either switch. The turn signal has already been replaced at least once, it did not have a stock one in it any more.
Should I just used small insulated spade lugs or is there a more elegant solution for two wire connections to go through the housing?
GregAmy
post Aug 3 2026, 04:24 PM
I'm a big fan of using Deutsch connectors for non-OEM connections.
While true Deutsch are top notch, they require a special barrel crimper. However, there are good-quality connectors that use connectors that leverage common crimpers that work well. Example:
https://www.amazon.com/DT-Connectors-Waterp...S/dp/B0CZ7K8G67
1 Members: saladin
- Lo-Fi Version Time is now: 3rd August 2026 - 06:21 PM
