> 71 steering wheel distance from housing
69146
post Aug 3 2026, 01:42 PM
The closest I can put the steering wheel to the housing holding the turn signal and key switch is 3/4 of an inch and it’s supposed to be about 1/8. It seems to hit on the metal tube housing the shaft. It looks like it is set too high. Any ideas on how I lower that shaft?
Thx
David
post Aug 3 2026, 03:53 PM
Post some pics of the front and back of the wheel. Front without the horn pan because I want to see if it's an early or late wheel. Many get switched over time.
Also want to see if you have the correct plastic hub on the back.
post Aug 3 2026, 04:53 PM
QUOTE(mepstein @ Aug 3 2026, 03:53 PM) *
Thx Mark. I’m in NJ till mid August so will post when I get back to Florida.
David
- Lo-Fi Version Time is now: 3rd August 2026 - 06:22 PM
