> Starting Problems, Starting with Throttle but Won't Idle
nmkimosabe
post Jul 31 2026, 04:18 PM
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
rfinegan
post Jul 31 2026, 04:23 PM
get a smoker from amazon, cheep and multi purpose.
L-Jets are notorious for vacuum leaks.. Great place to start
Check the timing again...Dwell effects timing
- Lo-Fi Version Time is now: 31st July 2026 - 06:42 PM
