| timofly |
Jul 29 2026, 01:03 PM
Member ![]() ![]() Group: Members Posts: 175 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
'74 2.0 with .010 oversize cylinders, original Jetronic fuel injection intact and works great 95% of the time. However, engine idles very slowly (almost off the bottom of the tach scale) and will eventually stall unless throttle is "goosed". Condition only occurs in high ambient temps after 15-20 minutes driving. Then hard to start without a bit of throttle, but starts fine with that little bit of throttle, so I don't think it's fuel vaporization. (Fuel pump has been moved forward and fuel lines are all SS.)
Runs normally otherwise. Cylinder head temp sensor? Idle adjustment? What? Any ideas would be appreciated. Tim |
| 914werke |
Jul 29 2026, 01:16 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,712 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
On top of the AFM is a recessed screw to adjust idle mix.
it will have IDK 12 or 14 discernible detent's. Verify where its currently set and increase adjustment as necessary 1 at a time |
Jul 29 2026, 01:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,689 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Is this ljet or djet?
Sounds like your idle mixture is a bit thin. If it is djet You can use the throttle body's idle screw to raise the idle and the pot on the ECU to richen it. Make sure the motor is hot and misbehaving before you try. I would start with the ECU pot first. Turn it clockwise a few clicks to richen. See if the idle stabilizes and comes up. Is this a new behavior or something that it's always done? |
Jul 29 2026, 01:34 PM
Is this ljet or djet? Sounds like your idle mixture is a bit thin. If it is djet You can use the throttle body's idle screw to raise the idle and the pot on the ECU to richen it. Make sure the motor is hot and misbehaving before you try. I would start with the ECU pot first. Turn it clockwise a few clicks to richen. See if the idle stabilizes and comes up. Is this a new behavior or something that it's always done? Do you have the retard on this distributor hooked up? Is it the stock distributor? |
| fiacra |
Jul 29 2026, 01:36 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 743 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
On top of the AFM is a recessed screw to adjust idle mix. it will have IDK 12 or 14 discernible detent's. Verify where its currently set and increase adjustment as necessary 1 at a time AFM is L-jet. Confusing because the OP says L-Jet, but a '74 2.0 should be D-Jet. Idle speed adjustment on D-Jet is on the throttle body. The knob on the ECU adjusts the idle fuel mixture, and I think that's what may need to be adjusted. |
| timofly |
Jul 29 2026, 02:07 PM
Is this ljet or djet? Sounds like your idle mixture is a bit thin. If it is djet You can use the throttle body's idle screw to raise the idle and the pot on the ECU to richen it. Make sure the motor is hot and misbehaving before you try. I would start with the ECU pot first. Turn it clockwise a few clicks to richen. See if the idle stabilizes and comes up. Is this a new behavior or something that it's always done? It's a D-Jet. I've owned the car for 20 years but this is the first time I've had this problem. Thanks for your reply. I'll give it a try. |
| timofly |
Jul 29 2026, 02:09 PM
Is this ljet or djet? Sounds like your idle mixture is a bit thin. If it is djet You can use the throttle body's idle screw to raise the idle and the pot on the ECU to richen it. Make sure the motor is hot and misbehaving before you try. I would start with the ECU pot first. Turn it clockwise a few clicks to richen. See if the idle stabilizes and comes up. Is this a new behavior or something that it's always done? Do you have the retard on this distributor hooked up? Is it the stock distributor? I assume it is, since its been with the car at least since 2006. |
| timofly |
Jul 29 2026, 02:11 PM
Is this ljet or djet? Sounds like your idle mixture is a bit thin. If it is djet You can use the throttle body's idle screw to raise the idle and the pot on the ECU to richen it. Make sure the motor is hot and misbehaving before you try. I would start with the ECU pot first. Turn it clockwise a few clicks to richen. See if the idle stabilizes and comes up. Is this a new behavior or something that it's always done? It's new. I've owned the car since 2006. I'll give that a try. Thanks. |
| timofly |
Jul 29 2026, 02:13 PM
| timofly |
Jul 29 2026, 02:14 PM
On top of the AFM is a recessed screw to adjust idle mix. it will have IDK 12 or 14 discernible detent's. Verify where its currently set and increase adjustment as necessary 1 at a time AFM is L-jet. Confusing because the OP says L-Jet, but a '74 2.0 should be D-Jet. Idle speed adjustment on D-Jet is on the throttle body. The knob on the ECU adjusts the idle fuel mixture, and I think that's what may need to be adjusted. My bad, it's a D-Jet. Thanks for the reply, I'll give it a try. |
| 914werke |
Jul 29 2026, 02:15 PM
Whoops OP used "Jetronic" My mind went to L-Jet
Lo-Fi Version | Time is now: 29th July 2026 - 04:03 PM |
