> HELP! Rear Swaybar Bushing Install
friethmiller
post Jul 27 2026, 04:15 PM
I need help here. I've just burned through 3 of these bushings trying to install them into my drop link. Every time I go to push on in, it cracks and falls apart during install. I don't understand why this is the case. Can someone tell me how to do it? I am absolutely at wits-end with these damn things. (IMG:style_emoticons/default/headbang.gif)
BTW, I just got new ones from AA this time. The 914rubber ones all failed. I'm sure it was me. Please help!!
NARP74
post Jul 27 2026, 04:29 PM
The AA ones could just be 914 Rubber ones, some parts are.
I think I put a small hole in the closed end to allow air and grease to escape and then used a clamp to slowly compress them on, going slowly and readjusting if needed. Heating them in hot water did not work for me. A heat gun while you do this might help. Too hot and they get mushy and collapse.
Ron914
post Jul 27 2026, 04:47 PM
I empathize with you Fred ,this has been the hardest job yet on my project .
I purchased mine from AA also and after many fails I it was suggested I buy authentic bushings from Porsche .
I purchased them from Pelican and still had a problem installing them . I heard about a shop around the corner from me called Fixasix and went over to see if they could do it for me .
I spent $40 but it was worth the frustration to me just to get it done . I came home excited to finally connect the rear sway bar and I must saw it still is not connected .
They heated them in hot water, used silicone lubricant , a vise and a large flat blade screwdriver .
I will say it took them about 30 minutes to install the bushings and it wasn't easy .
It takes a lot of force to pop them onto the balls .thus I have only one end installed on the sway bar end .
I used a large C clamp to accomplish that but never could get the other end attached to the shock bolts ( there is no where to use a C clamp for that side .
I am thinking I might have to. remove the shock bolts and install these ends first .
friethmiller
post Jul 27 2026, 05:34 PM
My issue is with just getting the bushing into the drop link.
post Jul 27 2026, 06:08 PM
We stuck the bushings in very hot water to get the pliable and then squeezed them in. Greased the ball and then popped them on with a big pair of channel lock pliers. (IMG:style_emoticons/default/beerchug.gif)
friethmiller
post Jul 27 2026, 07:25 PM
Thanks for the input! I just installed 3 without breaking them. I don’t believe it. I’ll post some pics and my technique, shortly.
friethmiller
post Jul 27 2026, 07:28 PM
friethmiller
post Jul 27 2026, 07:40 PM
Not easy but it can be done in about 5mins each.
1) put drop link into vise and tighten
2) warm up bushing with heat gun
3) Insert bushing in a way to take advantage of the vise’s pressure
4) use blade of screw driver to push lip into hole
Attached Image. Attached Image
1 Members: 913B
- Lo-Fi Version Time is now: 27th July 2026 - 09:47 PM
