Jun 30 2026, 01:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,929 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Anyone have an old VDO Cylinder Head Temp gauge around in decent condition?
I know these have fallen out of favor since they aren’t temperature compensated but curious if anyone still has one floating out there in the back of the parts bin, maybe unused & unloved? What cha’ got? |
| JamesJ |
Jun 30 2026, 01:50 PM
Member ![]() ![]() Group: Members Posts: 288 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
Not to hijack, but does anyone know if these can be rebuilt?
| 914Sixer |
Jun 30 2026, 05:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,506 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Might check with John Bell or NHS.
Jun 30 2026, 05:32 PM
Not to hijack, but does anyone know if these can be rebuilt? Sort of a loaded question. They are basically a sensitive milli-volt meter calibrated to a specific thermocouple output where x milli-volts output from the thermocouple equals y temperature. So if the actual movement is damaged it would be nearly impossible to fix. I’ve never seen the circuit but if it is using a op-amp or something similar to measure and amplify the milli-volt thermocouple output then a repair may be feasible. There is one on eBay right now where the movement seems to be damaged (showing 150F) with no thermocouple attached. Too expensive to take the risk on not knowing if it could be fixed so I posted here. |
| rfinegan |
Jun 30 2026, 06:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,207 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
I have one in my parts box, let me dig around a bit and find it
Lo-Fi Version | Time is now: 30th June 2026 - 07:09 PM |
