> FS: 4-Bolt 108mm Stub Axles + Output Flanges — 5 lug 914-6 Conversion
914Wes
post Jun 30 2026, 12:34 PM
4-Bolt 108mm Stub Axles + Output Flanges for 5 lug conversion
Up for sale: 4-bolt 108mm stub axles and matching 901/911 transmission output (joint) flanges. This is the classic combo for running the bulletproof GKN/Loebro 108mm CV setup on a 914 conversion.
Why this combo:
The stub axles slide directly into an early 911 wheel hub (same bearings as 69-73 911) and the output flanges bolt straight onto a 901/911-style transmission case. A well-known path for guys doing V8/big-six swaps who want to ditch the factory weak 914 CV's for the stronger 108mm 911/930 joints. Commonly cross-referenced to Porsche part numbers 901.332.232.00 (stub axle) and 901.332.209.15 (output flange).
Available separately or as a set:
  • Pair of stub axles (hub side) — $300
  • Pair of 4-bolt 108mm output/joint flanges (transmission side) — $300
  • Both pairs together — $550
Good used condition, ready to clean up and install. CV joints not included — pair with a set of early 911 axle assemblies (donor CVs) to complete the swap.
Payment: Venmo or Zelle
Shipping: At cost — est. $20 USPS within the US. Worldwide shipping available, PM for an international quote.
PM with questions.
—Wes
- Lo-Fi Version Time is now: 30th June 2026 - 07:09 PM
