| tygaboy |
Jun 29 2026, 01:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,833 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
After doing most of the work to add a heater core to my fresh air box, 3D printing some cool parts, fabbing the lines and buying everything else I need, I thought "do I really want all this when what I really need is a simple defrost function?"
I mean, I live in CA, don't drive the car if it's super cold or raining and I have heated seats. So the answer is "no, not gonna do it." Instead, I'm going to order 2 heated windshields (one for the LS car, one for the Ferrari build) from Heated Windsceens / Ricky Evans Motorsports in the UK: www.heatedwindscreen.com Cost is currently about $400 US plus shipping. When I told them I wanted two, they said they have to put them on a pallet and the shipping cost would stay the same if it's two or up to 5 or 6. So... Anyone interested in a heated windshield? As far as needed wiring, here's the response I got when I asked about wiring it: To get the best performance from the screen it’s a 25A fuse and relay both sides to a single switch, you can do just a single circuit and rate it higher, attached the inner two wires on the screen but then it will take longer to warm up. PM me if you're interested and we can work out the details. |
| JeffBowlsby |
Jun 29 2026, 02:02 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,296 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I wonder if these could be used as an antenna? :thinking:
| GregAmy |
Jun 29 2026, 02:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,682 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Are these laminated clear elements? Any photos?
It's a common racer trick to buy a rear window defrost grid and install it on the inside of the front windshield. Don't even notice it while driver after initial surprise. |
Lo-Fi Version | Time is now: 29th June 2026 - 03:48 PM |
