| gtbarnes |
Jun 28 2026, 09:04 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
If your gauge set is 'average' this will transform your car. Truly the best-looking set you will probably ever see. This started with 3 of the best examples I have seen. The spedo has factory paint on the needle and the tach was matched to it. Odo has been rebuilt to never have the inevitable gear failure problem. All gauges have been tested cleaned, and bezels are excellent, refinished and smooth(not chewed up) and can be removed easily if ever needed. Factory fresh appearance. All factory bulbs can be used as original or replaced with your led bulbs and can be used separately or along with the LED strips that have been installed in each gauge. The led installation produces the most 'factory intentional' looking led lighting that can be had. The adjustment is smooth from off to dim to bright. There is no way to tell that leds have been installed and the dimmer is usually hidden below the steering column in the factory cut out area of the lower dash pad. Its like Porsche engineered it this way. I will take $500 for this amazing set and I will cover shipping for you so you will surely do an honest review to let others know how your 914 driving experienced has changed. ![]() ![]() |
Lo-Fi Version | Time is now: 29th June 2026 - 12:36 AM |
