> Windshield replacement, Where to buy good clips for the metal trim
Ron914
post Jun 26 2026, 12:01 PM
I am getting ready to pull my windshield so I can replace my dash top and padding .
Where is the best place to buy new clips for the metal trim ?
I figured while it's out I might as well replace the windshield with one I can see out of .
burton73
post Jun 26 2026, 12:22 PM
Senior member, and old dude
QUOTE(Ron914 @ Jun 26 2026, 11:01 AM) *
Hi Ron,
I just want to point out that you will not Regret putting in a new windshield frame with your new windshield. As long as you're doing the windshield you might as well go fresh, but it is easy for me to spend your money.
Best Bob B
friethmiller
post Jun 26 2026, 12:50 PM
QUOTE(Ron914 @ Jun 26 2026, 01:01 PM) *
Ron,
I just went through this with the LE. Unfortunately, the 914rubber ones are too brittle. Buy the OE Porsche clips. They're like $4-5 per clip so be ready for that. (IMG:style_emoticons/default/blink.gif) They are not cheap but neither is the chrome that they are tasked with holding down. (IMG:style_emoticons/default/biggrin.gif) Pelican sells them.
aharder
post Jun 26 2026, 01:03 PM
I ended up buying OEM from a dealer. All others would not work.
Ron914
post Jun 26 2026, 01:15 PM
QUOTE(friethmiller @ Jun 26 2026, 01:50 PM) *
Ron,
Thanks Fred ,
Pelican is local for me so I will order some up .Do you know how many I will need ?
Rom
slowrodent
post Jun 26 2026, 01:18 PM
I very recently ordered a full set from 914Rubber and some "extras" from RMeuropean. I found the RM ones to work quite well.
Ron914
post Jun 26 2026, 01:19 PM
QUOTE(burton73 @ Jun 26 2026, 01:22 PM) *
Hi Ron,
Best Bob B
Hi Bob ,
Mine looks pretty good but yours looks a whole lot better . Is there a source for the metal trim around the windshield? Its always easier to spend someone else's money and more fun .
Ron
post Jun 26 2026, 01:25 PM
QUOTE(Ron914 @ Jun 26 2026, 03:15 PM) *
Ron,
Thanks Fred ,
Rom
I believe it’s 19. The 914rubber ones are too brittle and result in a failed install when they crack.
friethmiller
post Jun 26 2026, 01:31 PM
QUOTE(mepstein @ Jun 26 2026, 02:25 PM) *
Ron,
Thanks Fred ,
Rom
(IMG:style_emoticons/default/agree.gif) Yep, 19.
flxzcat
post Jun 26 2026, 02:10 PM
Does one have to pull the windshield to replace the 19 clips and aluminum trim?
Thanks in advance,
Paul
post Jun 26 2026, 02:40 PM
QUOTE(flxzcat @ Jun 26 2026, 04:10 PM) *
Thanks in advance,
Paul
Yes to the clips, no to just replacing trim. Use a trim tool to remove the trim. It's fragile.
post Jun 26 2026, 04:52 PM
Hey nice rack! -Celette
Do not use a trim tool. Slide a razor blade between the frame and trim and just cut the clips. It is not worth bending up the fragile trim.
post Jun 26 2026, 06:29 PM
QUOTE(rick 918-S @ Jun 26 2026, 06:52 PM) *
That’s an even better idea.
4 User(s) are reading this topic (1 Guests and 1 Anonymous Users)
2 Members: Flyinlow, T.Rick6
- Lo-Fi Version Time is now: 26th June 2026 - 06:58 PM
