| Medtner3 |
Jun 24 2026, 06:38 PM
Member ![]() ![]() Group: Members Posts: 191 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I had a hyper blinking tail light , removed bulb from other side to test then that one started hyper blinking. I opened both up to clean contacts and found that the left side had tons of corrosion and rust. The right side was okay.
Turns out the flasher relay was going out. However, is there anyone who professionally rebuilds the taillight assembly not the lens obviously mine are pretty good no cracks. There is a lot of rust and corrosion and not sure I can get it to perfection without help Thanks |
| dtmehall |
Jun 24 2026, 06:44 PM
Member ![]() ![]() Group: Members Posts: 302 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| Spoke |
Jun 24 2026, 07:23 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,399 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
@bdstone
There are rear light housings on ebay for $125-$150 if you need to get a new one. Try using a dremel with a small wire wheel to clean the socket. Then gently scrape the center contact button with a razor knife or small flat head screwdriver. All you're looking for is to make good electrical contact. I don't know of anyone refurbishing these housings. |
| dtmehall |
Jun 24 2026, 07:35 PM
be careful of ebay.
i bought a housing a couple of years back, and it was cracked and smashed. i had to epoxy it back together again to be fair, the seller gave me a credit be careful when abrading the contact surfaces. i don't think that it is all copper |
Lo-Fi Version | Time is now: 24th June 2026 - 08:36 PM |
