> Convert back to D Jet Fuel Injection-, Distributor Static Timing.
young55961
post Jun 19 2026, 01:32 PM
I set the engine to TDC on cylinder #1. The timing mark is lined up with the case split. Both the intake and exhaust rocker arms have a little movement when I turn the fan pulley slightly left and right.
The distributor rotor is pointing to about the 8 o'clock position.
Does this look correct?
Also, how do I set the static ignition timing on this engine?
Artfrombama
post Jun 19 2026, 02:38 PM
Artfrombama
QUOTE(young55961 @ Jun 19 2026, 02:32 PM) *
Both cyl. #1 valves should be closed to be on TDC compression, otherwise the engine is on TDC exhaust stroke
I use a continuity tester to set static timing. Align your timing marks and slowly turn the distributor until the points break (no continuity)
Jack Standz
post Jun 19 2026, 03:30 PM
If the #1 intake and #1exhaust rocker arms are moving at/around "TDC", you are not at TDC for the #1 cylinder's compression stroke.
You could be at TDC for the #1 cylinder but you may be on the exhaust stroke, but maybe not. Reconfirm everything. Things like the fan marking for TDC (some Type IV motors don't have a mark on the fan for TDC), where the distributor is installed, etc.
young55961
post Jun 19 2026, 04:52 PM
QUOTE(Jack Standz @ Jun 19 2026, 04:30 PM) *
I checked both the fan and the flywheel, and all the timing marks line up.
I rotated the engine one full revolution, and now the rotor is pointing to the 2 o'clock position. The problem is that the air temperature sensor is blocking distributor vac. I have to remove the sensor; otherwise, I can't set the timing.
Artfrombama
post Jun 19 2026, 05:17 PM
Artfrombama
#1 piston is at TDC twice per cycle. Once during the exhaust stroke and once during the compression stroke. The timing marks will align on the exhaust as well as the compression stroke.
Static timing video
- Lo-Fi Version Time is now: 19th June 2026 - 08:02 PM
