> Convert back to D Jet Fuel Injection-, Wire harnessess- Injector Ground
young55961
post Jun 18 2026, 02:34 PM
I have a question about the ECU wiring harness.
There are three pairs of white wires with female spade terminals on the harness. I believe they are the ground wires for the fuel injectors, but I can't find where they are supposed to connect.
Should these wires be connected to the negative (-) terminal of the ignition coil?
If anyone has a photo showing the correct connection, I would really appreciate it. Thank you!
brant
post Jun 18 2026, 02:46 PM
There was supposed to be a three prong connector on the rear engine block through bolt
Back center of engine bay
2 of the three pairs are injector grounds. The third pair is grounds for the ECU and TPS.
They attach to a Tri-spade male terminal located on an engine case through-bolt at the top rear of the engine case, under the air plenum.
young55961
post Jun 18 2026, 02:52 PM
QUOTE(JeffBowlsby @ Jun 18 2026, 03:46 PM) *
Tks.
Let me check.
9 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
1 Members: young55961
- Lo-Fi Version Time is now: 18th June 2026 - 04:11 PM
