| Speedo |
Jun 8 2026, 03:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 626 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains
I'm in the process of recovering my seats. The fiberglass passenger bucket has three holes on both sides of the base. Does it bolt directly to the floor? No brackets? I can't remember how it came out of the car. Seems weird to bolt it directly to the floor?
| gereed75 |
Jun 8 2026, 04:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,435 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
dont have mine out in front of me but I seem to remember that it bolts down with nuts on studs that protrude from the floor pan
Im sure someone else will report with the definitive answer. |
| aturboman |
Jun 8 2026, 04:23 PM
Member ![]() ![]() Group: Members Posts: 164 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
The fiberglass base is held to the floor by (4) small studs on the floor pan and 2 small bolts on the cross member. Here is a 6 with the attachment points circled.
I believe both are M6 fasteners as I recall. Attached thumbnail(s) |
| DennisV |
Jun 8 2026, 04:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 968 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Does it bolt directly to the floor? No brackets? I can't remember how it came out of the car. Seems weird to bolt it directly to the floor? Yep. Directly to the floor. I just put mine back last weekend. @aturboman memory is correct. M6 nuts qty 4. M6 x15 bolts qty 2 (900 075 193 08). Plus washers. I think you will want to place your vinyl floor covering for the tunnel, door sills, and front seat rail before you install the backpad or seat bottom. |
| Speedo |
Jun 8 2026, 05:38 PM
Thanks everybody!
Lo-Fi Version | Time is now: 8th June 2026 - 07:56 PM |
