> Thermostat Cable
L-Jet914
post May 12 2026, 11:49 PM
Good evening fellow Teeners. I have a question regarding the thermostat cable. How does the thermostat cable thread into the thermostat? I was looking at replacement cables and it doesn't look like it has a threaded section to the cable. I started to disassemble the underside to replace my push rod tube seals and perform a valve adjustment. I know I need to replace my thermostat which I just found out today had failed after lord knows how long (still has the VW logo and part number). I tried to remove the thermostat cable from the old thermostat and it snapped off inside which I am not surprised due to the age of the vehicle. Thank you in advance. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 13th May 2026 - 12:50 AM
