| IronHillRestorations |
May 12 2026, 01:58 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,937 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
For sale: set of headlight assemblies. Cover doors, black plastic surrounds, headlight brackets, chrome rings, and lamps. Includes nylon pivot bushings, no pivot arm pins. Screws for retaining rings are not corroded and unscrew easily. Brackets have some small areas of light surface rust, but it’s very minimal and overall the brackets are are very nice. Black plastic surrounds are not cracked and intact, but they could use some refreshing. Cover doors have some small areas of surface rust that got painted with red primer, but they are straight and solid. Headlamps are included. $80 plus actual shipping. I prefer a check, but I can take Venm or PayPal if you add 3.5% to cover the fees.
| friethmiller |
May 12 2026, 02:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,254 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
excellent deal, IMHO (IMG:style_emoticons/default/smile.gif)
| bdstone914 |
May 12 2026, 03:06 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,305 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Based on the black surrounds i think tbose are late sets.
The housings have a different offset between earky and late. Installing the wrong set will off center them in the buckets. I have to look at the stop tab to tell the difference. GLWS |
May 12 2026, 03:24 PM
Based on the black surrounds i think tbose are late sets. The housings have a different offset between earky and late. Installing the wrong set will off center them in the buckets. I have to look at the stop tab to tell the difference. GLWS Attached image(s)
Lo-Fi Version | Time is now: 13th May 2026 - 12:50 AM |
