| HFC3 |
May 11 2026, 02:39 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 14-December 25 From: Virginia Member No.: 29,151 Region Association: MidAtlantic Region |
| HFC3 |
May 11 2026, 02:40 PM
| BillC |
May 11 2026, 04:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
I believe the rear rubber seal should extend down, not forward. The rear seal has two "flaps", and I believe those flaps fit over the rear sheet metal on the engine, one in front and one behind. At least, that's how I did it in my car.
| HFC3 |
May 11 2026, 05:17 PM
I believe the rear rubber seal should extend down, not forward. The rear seal has two "flaps", and I believe those flaps fit over the rear sheet metal on the engine, one in front and one behind. At least, that's how I did it in my car. I am sure you are right! Many Thanks |
| Literati914 |
May 12 2026, 07:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,315 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
So there’s multiple ways for it to sit in the track? How do you get it facing down (IMG:style_emoticons/default/confused24.gif)
| Shivers |
May 12 2026, 09:03 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,384 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| porschetub |
May 12 2026, 05:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,104 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Does the rubber flap go towards the front of the car not quite sure what it would look like in my mind if I flipped it that way. I really couldn’t find any good pictures showing it clearly. Yep thats correct, I used a NOS T2 bus one I bought in my country ,side rubbers came from Pelican back then , make sure you work the seal in the groove and don't cut it too short , you can cut it back but not make it longer !!,cheers. |
Lo-Fi Version | Time is now: 13th May 2026 - 12:49 AM |
