| cabrioartie |
May 1 2026, 07:45 PM
Newbie ![]() Group: Members Posts: 26 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
Hi,
Recently acquired '74 2.0l, I have finally gotten the engine running properly and I'm now moving on to the many other things which need to be fixed. So, after following the site for a while, I can say, I've never seen a hole like this on anyone's car. Any guesses as to why or what it was used for? Thanks ![]() |
| bkrantz |
May 1 2026, 07:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,678 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Doo you mean the small hole in the shelf next to the snorkel? I would guess somebody wanted to run a wire and they did the second most easy thing (after just snaking the wire past the engine shelf rubber).
| cabrioartie |
May 1 2026, 08:05 PM
Doo you mean the small hole in the shelf next to the snorkel? I would guess somebody wanted to run a wire and they did the second most easy thing (after just snaking the wire past the engine shelf rubber). Yes, that's the one I'm asking about. Should I do anything about this hole? Or just leave it the way it is, or seal it up? |
| dtmehall |
May 1 2026, 08:28 PM
Member ![]() ![]() Group: Members Posts: 279 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
are your sure that it's just not this?
Plastic Fastener 914 Engine Insulation Padding Clip |
| dtmehall |
May 1 2026, 08:36 PM
maybe a replacement from a FLAPS?
| TRP |
May 1 2026, 09:42 PM
Member ![]() ![]() Group: Members Posts: 334 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Lo-Fi Version | Time is now: 2nd May 2026 - 02:03 AM |
