| sdoolin |
Apr 25 2026, 11:05 AM
Member ![]() ![]() Group: Members Posts: 421 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Voltmeter shows between 10V - 12V at idle (and everywhere else). Voltmeter drops to 10V when headlights, flashers, and wipers switched on. Multimeter across the battery terminals at idle reads 12.5V.
Alternator was verified good several years back when I built this engine. I'm not sure what to check next? |
| mgphoto |
Apr 25 2026, 11:30 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,449 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Voltmeter shows between 10V - 12V at idle (and everywhere else). Voltmeter drops to 10V when headlights, flashers, and wipers switched on. Multimeter across the battery terminals at idle reads 12.5V. Alternator was verified good several years back when I built this engine. I'm not sure what to check next? Isolate the battery and check voltage. If you charge the battery till it is full, see how long it takes for the voltage to drop without a load, that will tell you the condition of the battery. |
| sdoolin |
Apr 25 2026, 11:56 AM
OK, so I checked some more things, and I am NOT GOOD with a multimeter. But, here's what I found (all measurements at idle):
Battery = 12.5V Green Wire from alternator and chassis ground = 4.5V Brown wire from alternator and chassis ground = 0.05V (essentially 0) Red wire from alternator and chassis ground = 13.8V |
| mgphoto |
Apr 25 2026, 02:58 PM
13.8 your alternator looks to be ok but your battery might be dead, look up minimum voltage and full charge for the battery you are using. This measurement is made with the engine off.
| fixer34 |
Apr 25 2026, 03:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
OK, so I checked some more things, and I am NOT GOOD with a multimeter. But, here's what I found (all measurements at idle): Battery = 12.5V Green Wire from alternator and chassis ground = 4.5V Brown wire from alternator and chassis ground = 0.05V (essentially 0) Red wire from alternator and chassis ground = 13.8V Assume red wire to chassis ground reading is being made at the battery positive terminal while the engine is running? Do the same measurement across the actual battery terminals. Voltage reading should be the same, or very close. If it isn't, check/clean the battery terminal connections, the red wire connection to the positive post, the ground strap from battery to chassis, and the chassis strap underneath to the transmission. Unbolt and make sure the connections are clean/shiny. |
| sdoolin |
Apr 25 2026, 04:13 PM
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight.
Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board. |
| mgphoto |
Apr 25 2026, 06:25 PM
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight. Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board. So what is the voltage, after sitting on the trickle charger and then after sitting all night without the charger? |
Apr 25 2026, 06:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,630 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Is the voltage in the 13.5 - 15v when running?
If not I would pull the alternator for a bench test at your local starter/alternator rebuilder |
| fixer34 |
Apr 25 2026, 08:14 PM
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight. Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board. Verify at those spots again, then check at the battery terminals. Readings should be the same. |
| Spoke |
Apr 25 2026, 08:55 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,376 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
OK, so I checked some more things, and I am NOT GOOD with a multimeter. But, here's what I found (all measurements at idle): Battery = 12.5V Green Wire from alternator and chassis ground = 4.5V Brown wire from alternator and chassis ground = 0.05V (essentially 0) Red wire from alternator and chassis ground = 13.8V Are these measurements from the 3 wires from the alternator connector at the relay board? If the D+ red wire at the alternator connector on the relay board is 13.8V, then the alternator stator is functional. If the large red wire from the alternator to the starter to the battery is in good shape but the battery is measuring 12.5V it would appear that the diodes in the alternator may not be functional. If you charge the battery, what voltage do you measure while charging. If the battery can charge to 14V while charging, again the discrepancy between D+ and VBAT may be because of alternator diodes being damaged. |
Lo-Fi Version | Time is now: 26th April 2026 - 12:53 AM |
