| Steve1956 |
Apr 23 2026, 09:46 AM
Newbie ![]() Group: Members Posts: 40 Joined: 4-November 22 From: Morocco,Indiana Member No.: 26,966 Region Association: None |
Hello,what model Weber carbs were used on the 76' 914 2.0lt engine? I can't find anything but "Weber' on the casting. Thanks
Apr 23 2026, 10:24 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,800 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Carbs were never standard to any 914/4 US cars.
Need photos (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Apr 23 2026, 10:45 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,615 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Many original Bosch fuel injection cars have been converted to twin Weber carbs over the years, generally 40IDF was the carb of choice
| Ninja |
Apr 23 2026, 11:01 AM
Member ![]() ![]() Group: Members Posts: 199 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
The Hawk is right! A common set up is a single progressive 2 barrel where the original FI plenum was mounted (centered over engine). This set up is a performance DECREASE over the original fuel injection but dead simple to work on and tune. The "normal" performance carb set up is two 2 barrel down draft set up. You end up with a single barrel feeding only one cylinder (ITB) and you have 4 individual carburetors feeding the engine. The "proper" Weber for a near stock to medium modified 76 2.0l would be the 40IDF. Most come stock with 32mm venturis and those don't work well unless the engine is highly modified and/or run at higher RPM (track car). A good starting base for a stock/mild 2.0L would be a 40 IDF with 27-28mm venturis, 130 mains, 200 airs, and 50-55 idles. To work well, this set up usually requires ignition system improvements. The 123 distributors are an easy button. The ITB set up is harder to tune and the base engine needs to have good compression and leak down readings across all cylinders. The center progressive set up HIDES differences between cylinders and the IDF set up AMPLIFIES differences. Most Weber carbs have their identifying markings stamped into the base of the casting just above where they mount on the manifolds. Sometimes the stampings are vague or very light. |
| Steve1956 |
Apr 23 2026, 11:41 AM
Carbs were never standard to any 914/4 US cars. Need photos (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) WoW! did not know that,this is a parts car I bought.I thought it strange that there was an aftermarket low pressure fuel pump mounted in the engine bay. |
| Steve1956 |
Apr 23 2026, 11:44 AM
(IMG:style_emoticons/default/agree.gif) The Hawk is right! A common set up is a single progressive 2 barrel where the original FI plenum was mounted (centered over engine). This set up is a performance DECREASE over the original fuel injection but dead simple to work on and tune. The "normal" performance carb set up is two 2 barrel down draft set up. You end up with a single barrel feeding only one cylinder (ITB) and you have 4 individual carburetors feeding the engine. The "proper" Weber for a near stock to medium modified 76 2.0l would be the 40IDF. Most come stock with 32mm venturis and those don't work well unless the engine is highly modified and/or run at higher RPM (track car). A good starting base for a stock/mild 2.0L would be a 40 IDF with 27-28mm venturis, 130 mains, 200 airs, and 50-55 idles. To work well, this set up usually requires ignition system improvements. The 123 distributors are an easy button. The ITB set up is harder to tune and the base engine needs to have good compression and leak down readings across all cylinders. The center progressive set up HIDES differences between cylinders and the IDF set up AMPLIFIES differences. Most Weber carbs have their identifying markings stamped into the base of the casting just above where they mount on the manifolds. Sometimes the stampings are vague or very light. Right after I posted , I measured the throttle plate bore and found it was 40mm. Then saw what looked like a faint number on the mounting flange,wire brush and 40 IDF 70 8K. |
Apr 23 2026, 12:41 PM
If you are parting this one, I might be interested in a few bits
Lo-Fi Version | Time is now: 23rd April 2026 - 04:27 PM |
