| cause |
Apr 17 2026, 05:11 PM
Newbie ![]() Group: Members Posts: 46 Joined: 6-May 21 From: new york Member No.: 25,514 Region Association: None |
How miserable is it to weld in a new battery tray without dropping the motor? My car is far from a clean specimen so I'm not worried about it not being perfect. Probably asked and answered but I haven't seen it in my search
| Shivers |
Apr 17 2026, 07:12 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,351 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
How miserable is it to weld in a new battery tray without dropping the motor? My car is far from a clean specimen so I'm not worried about it not being perfect. Probably asked and answered but I haven't seen it in my search I was in the hole where the engine goes when I welded mine. You'd be doing it up side down I guess. I'd pull the engine lid to get more room and I'd add a light to the engine bay to help get the wire in the right place. Cover everything up. I drilled 3/8" holes and did rosebuds to hold it in, once ground down they look like big spot welds. Good luck |
| bkrantz |
Apr 17 2026, 07:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,662 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Between making the job harder, not getting it right, and collateral damage, I recommend dropping the engine.
Lo-Fi Version | Time is now: 17th April 2026 - 09:25 PM |
