| FlacaProductions |
Apr 7 2026, 07:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Greetings,
The set screw hole on the bottom collar of my Amco shift knob has cracked and needs to be re-drilled and tapped. Picture is not mine but accurately illustrates the issue although this set screw seems much larger than mine. I have filled the hole/crack with JB weld and the whole collar is solid. What's my best approach to re-drill and tap? Go thru the JB at the (approximate) same point or pick a new point of entry? I have the original screw but haven't figured out the size/thread just yet. Thanks! Brian |
| Beach914 |
Apr 7 2026, 11:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,003 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California
I have one with the same problem. will probably drill and tap in 180 degree location after filling and blending the damaged hole with jb weld.
Lo-Fi Version | Time is now: 7th April 2026 - 11:29 PM |
