> Rusted Screws Advice, Headlights
chandler1969
post Apr 7 2026, 07:03 AM
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO.
DennisV
post Apr 7 2026, 07:13 AM
QUOTE(chandler1969 @ Apr 7 2026, 06:03 AM) *
Went through this myself not long ago.
You could try hitting them with a small propane or butane torch if you can control the flame.
Otherwise I'd grab them with vice grips to break them free. Even if it's the threaded side for a secure grip. Replace the screws.
Last resort cut them off with a Dremel.
Jamie
post Apr 7 2026, 07:24 AM
QUOTE(chandler1969 @ Apr 7 2026, 05:03 AM) *
Chandler1969 from Georgetown KY? Have we ever met, and we need to get in touch!
post Apr 7 2026, 07:37 AM
A bit of heat from an torch and then touch a piece of paraffin to the hot metal. Unlike oils that evaporate, paraffin will wick into the threads when hot. Works well most of the time.
chandler1969
post Apr 7 2026, 07:56 AM
QUOTE(Jamie @ Apr 7 2026, 05:24 AM) *
Not sure if we have, although I'm in Lawrenceburg now but I do go to Georgetown from time to time.
chandler1969
post Apr 7 2026, 07:57 AM
QUOTE(DennisV @ Apr 7 2026, 05:13 AM) *
Thanks, I was thinking the same but wanted some expert advise before proceeding!
chandler1969
QUOTE(mepstein @ Apr 7 2026, 05:37 AM) *
A bit of heat from an torch and then touch a piece of paraffin to the hot metal. Unlike oils that evaporate, paraffin will wick into the treads when hot. Works well most of the time.
I will give that a try to see if that will help break them loose.
914werke
post Apr 7 2026, 08:43 AM
Here you go!
http://www.914world.com/bbs2/index.php?s=&showtopic=360108&view=findpost&p=3007648
914werke
post Apr 7 2026, 08:44 AM
Whoops link didnt work ...Here you go!
HERE
Ive found the best way is to use a small set of vise grip to bite the sides.
The screws are junk anyway so go to town , all you have to do is loosen them
chandler1969
post Apr 7 2026, 09:06 AM
QUOTE(914werke @ Apr 7 2026, 06:44 AM) *
Here you go!
HERE
Thanks! Placing an order!
chandler1969
post Apr 7 2026, 09:08 AM
Here you go!
HERE
Well, you're out of stock on the fasteners.
914werke
post Apr 7 2026, 09:14 AM
Nah Im just remiss on maintaining the store inventories. I have them. Ill update.
(IMG:style_emoticons/default/headbang.gif)
1 Members: jsh
- Lo-Fi Version Time is now: 7th April 2026 - 11:29 PM
