| nivekdodge |
Apr 5 2026, 07:02 PM
Member ![]() ![]() Group: Members Posts: 332 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
The bolts are stiff, so not wanting to rip out the fasteners. Do the bolts thru the hinge and into the fender apron have any adjustment to them, (IMG:style_emoticons/default/smash.gif) if I get them loose?
Kevin |
| Ishley |
Apr 5 2026, 08:04 PM
Member ![]() ![]() Group: Members Posts: 338 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Are you talking about door adjustments?
| 76-914 |
Apr 5 2026, 08:22 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Yes, the nuts are caged but not captive. You should get about ~5mm movement from each nut. Most adjustments to the door fit can be made with a 2x4 in minutes unless there is damage at the door post. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 6th April 2026 - 05:16 PM |
