| DennisV |
Apr 5 2026, 05:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 890 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
This was another 5 minute job that turned into a hour. A few things I ran into that will maybe save someone else some time.
Maybe the specs are different for different manufacturers. The ones I received were made by Hamburg-Technic. The cone was too wide / rubber to hard to fully seat. I tried: * Pushing from top with pliers * Pulling from bottom with pliers * Screwing them in * Dish soap * Heat gun 1. Buy extras. I broke 6 of these. 2. Reduce the diameter. I used a Dremel with a sanding cylinder to grind down the diameter of the cone area. Lubricated with dish soap. 3. Install the mounts on the pump first. They are nearly as hard to get seated in the pump base as to pull through the body. I was able to get them with dish soap and needle nose pliers. 4. Have someone push down on the pump with the mounts inserted in the holes. Pull from inside with with pliers. Not an exciting topic, but knowing this in advance would have same me some grief. Thank goodness I had extras. ![]() |
| aturboman |
Apr 5 2026, 11:09 AM
Member ![]() ![]() Group: Members Posts: 152 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
My experience is the only the Genuine Porsche mounts are elastic enough to stretch and allow them to be installed. I tried multiple after market ones and all snapped before they pulled through.
The process is to spray the rubber and hole with silicone spray and from the inside of the car pull downward with a needle nose plier on the end. This elongates the mount and they pull easily into place. Again this only worked with the Genuine rubber part. |
| jim_hoyland |
Apr 5 2026, 11:48 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,043 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
What does the finished installation look like ? (IMG:style_emoticons/default/popcorn[1].gif)
| PanelBilly |
Apr 5 2026, 12:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,951 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Sex lube works wonders
Lo-Fi Version | Time is now: 5th April 2026 - 01:47 PM |
