| Geezer914 |
Apr 4 2026, 03:48 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,267 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Replaced the oil cooler seals and it is still leaking oil. Start up pressure is 80lbs. Would that cause the oil to leak at the seals? Anyone ever had an oil cooler leak? (IMG:style_emoticons/default/confused24.gif)
Apr 4 2026, 05:01 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,595 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
They shouldn’t leak, even at that pressure. When we test a 911 cooler, we pump them up to 60+ to make sure they aren’t leaking.
| 914sgofast2 |
Apr 4 2026, 05:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 798 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
New or used oil cooler? Jake Raby just had a rant about the poor quality of the new oil coolers being sold that he posted two (2) days ago on his Type 4 performance engine Facebook page called "Raby's Aircooled Technology". Raby stated that he only uses old German made oil coolers that he has thoroughly cleaned using his ultra sonic cleaner and his "special sauce" proprietary cleaning fluid. Raby said his cleaning process takes several days of cleaning and degreasing and frequent changes of the special cleaning fluid he has developed for use in his ultra sonic cleaning machine. And before you ask, he does not sell his refurbished oil coolers unless you buy a complete engine from him.
| brant |
Apr 4 2026, 07:06 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,170 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Used to run a type 4 race motor with a big oil pump and 100 psi cold starts
Never had problems with cooler seals (fresh). Blew safety valves on the Accusump at 120psi on a cold race morning below freezing in Topeka |
| Geezer914 |
Apr 5 2026, 05:10 AM
Thanks for the replies, I'll have to remove the oil cooler and have it pressure checked. It's an original oil cooler.
| Shivers |
Apr 5 2026, 06:03 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,344 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Thanks for the replies, I'll have to remove the oil cooler and have it pressure checked. It's an original oil cooler. I'll toss this out there because it happened to me. Did an oil /filter change and valve adjustment then took it for a drive. I noticed smoke so I went back home. I crawled under and it looked like it was the cooler. I was ready to drop the engine but then thought about the filter I just replaced, so I checked it. The POS Fram filter did not tighten all the way down and blew oil all over. It was hitting something solid and would not seat. |
| Geezer914 |
Apr 5 2026, 08:41 AM
Fram filters are shit.
Apr 5 2026, 11:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Leaking oil pressure sensor / idiot light sensor often present exactly like leaking oil cooler seals.
| Chad911sc |
Apr 5 2026, 11:48 AM
Member ![]() ![]() Group: Members Posts: 301 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I just rebuilt my engine and used a new oil cooler from Auto Atlanta. It took some grinding and cutting to make it fit, but it didn’t leak a drop. Had to grind off the lip on both sides to get the factory strap at the rear to fit, and had to grind off some of the lower support to be able to get the nut onto the oil filter stud. It wasn’t cheap to buy like so many of the other options out there, but worth it.
Lo-Fi Version | Time is now: 5th April 2026 - 01:47 PM |
