| Flyinlow |
Mar 31 2026, 05:39 PM
Flyinlow ![]() ![]() Group: Members Posts: 138 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Nearing the end of my restoration drove car today for first time in 30 years!! Start up is 1000 rpm a little high…. Then on its own goes to 3000 rpm then seems to settle to 2500 rpm.. when shifting rpm rises? I checked throttle cable for routing… all good and it did decel but not quickly as it seemed to be hunting any help much appreciated.TIA Dennis (IMG:style_emoticons/default/blink.gif)
| Flyinlow |
Mar 31 2026, 05:44 PM
Car is 74 2.0 D jet and I had no response from idle adjustment screw
Mar 31 2026, 05:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,506 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
If you just start the car and let it sit, what does it do? Cold or hot?
| mgphoto |
Mar 31 2026, 05:53 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Big air leak in the intake.
| Flyinlow |
Mar 31 2026, 06:14 PM
| Flyinlow |
Mar 31 2026, 06:16 PM
| mgphoto |
Mar 31 2026, 08:37 PM
If it changes when it gets hot must be something with the AAR, Auxiliary Air Regulator, for cold weather starting.
| mgphoto |
Mar 31 2026, 08:41 PM
If the idle undulates, it usually is the idle air screw out too far, but you said screwing it in made no difference.
The next possibility would be an air leak. |
| porschetub |
Mar 31 2026, 11:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Big air leak in the intake. Certainly sounds like it, quick test on the throttle cable ,when the engine is up to temp disconnect it and see what it does . The vacuum leak is a telltale of loose /leaking air hose/s or many other reasons ,D-jet isn't happy with air leaks ,even a small leak will render the air screw to no non -op . Go back and check everything ,cheers. |
| Geezer914 |
Apr 1 2026, 03:59 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,260 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Do a smoke test to find the air leak.
| rfinegan |
Apr 1 2026, 05:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Disconnect and plug the vacuum Lines to AAR and the decal valve and confirm your Idle settings.
Also just a few degrees to much on your timing will give you a high idle too. A visual inspection for vacuum leaks or a smoker(cheep on amazon )will help pinpoint any vacuum leaks |
| Flyinlow |
Apr 1 2026, 02:59 PM
If it changes when it gets hot must be something with the AAR, Auxiliary Air Regulator, for cold weather starting. Culprit found!! Attached thumbnail(s) |
Apr 1 2026, 04:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,571 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
(IMG:style_emoticons/default/beer.gif) congrats
"first time running in 30 years" major accomplishment (IMG:style_emoticons/default/beer.gif) |
| Jamie |
Apr 1 2026, 07:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,201 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Lo-Fi Version | Time is now: 1st April 2026 - 11:18 PM |
