> New Member, old car
TACAN73
post Mar 27 2026, 06:50 PM
So I bought a 914...
914's have been on my list for years. Last year, an Irish green '73 1.7 appeared on Craigslist and with some serendipity, a cashier's check, and a helpful friend it's now in my driveway. I did my pre-purchase research on 914world, and let me say, what a great resource this community has built. It made me very confident I could figure out what to do with this car, and how to get it right. After a year of research, disassembly, cleaning, a borescope, more research, and so on, I am getting close to a plan. Having a 914, even under a cover, in your driveway and you get to hear a lot about how your neighbors spent their time in high school. I even had a visit from a guy down the street with a 1972 he has owned for 30 years. The Good: the engine runs, the transmission shifts, and the bodywork seems straight. The Bad: passenger long is more of a suggestion in places and one of the previous owners (PO) tacked about 30+ hand made patch panels all over the place, including the entire passenger floor. The paint job seems to be the factory color, but the chassis plate and bolt heads are red, so not original. I live on a hill, so I don't think the 1.7 is going to cut it. I thought about a -6 conversion, then i saw what air cooling costs these days. All of this also has to happen in my driveway...
There's plenty of inspiration in this forum, though.
The current plan is to pull the motor, transmission, wiring harness, the brakes and replace those. I am split between the K and LS swap, having seen excellent examples of both. Boxster 6 speed, brakes and 5-lugs for sure. The body is going to get put on a rotisseries, repaired where needed, strengthened, and some flares added. I am not too concerned with doing a restoration, rather building a solid platform. I read Roy Smith's excellent book (The Racing 914's) and I think I am going to keep the exterior and interior close to what was raced in period (rally and the Marathon de la Route).
RFI's
1. Any recommendations on where to put reinforcements for a cage ?
2. Any advice on dealing with prior repairs- cut out or use (or threads that discuss this)?
3. The car has (to my surprise) all original glass. I don;t know if this should come out or stay in as the car gets structure built around it for a rollover stand/rotisserie. Any pointers appreciated.
All of the extra 914 stuff will be posted to the classifieds here first. Progress will be slow as I have an active racing program and two small kids. Looking forward to it!
KELTY360
post Mar 27 2026, 07:03 PM
914 Neferati
bkrantz
post Mar 27 2026, 07:25 PM
Welcome and good luck!
From memory, when I built a 914 race car back in the 90s I mounted the cage to L-shaped plates that were welded to the top and inner side of the longs--not the floor.
As for design and specific location of tubes and mounting, that depends on how much you want to compromise access and interior obstruction with rigidity and crash performance.
bkrantz
post Mar 27 2026, 07:26 PM
Also,
POST PHOTOS!!!
post Mar 27 2026, 08:06 PM
As mentionned... (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
For the roll cage, you may want to contact Chris Foley at Tangerine racing.
On your rustoration project, if the passenger side long is gone, chances are the driver's is somewhat compromised, but you will see. As for previous repairs... (IMG:style_emoticons/default/dry.gif)
A couple of members are currently doing restoration work outside, Paul and amazing Fred. There is a forum for restorations only where you will find a lot of information.
Paul: http://www.914world.com/bbs2/index.php?showtopic=301473
Fred: http://www.914world.com/bbs2/index.php?showtopic=368359
Build threads forum: http://www.914world.com/bbs2/index.php?showforum=78
Good luck with your project! (IMG:style_emoticons/default/smash.gif)
SO.O.C914er
post Mar 27 2026, 09:58 PM
I’m not seeing anything green here!!
post Mar 28 2026, 12:11 AM
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welder.gif)
TRP
post Mar 28 2026, 08:43 AM
Welcome to the funny farm.
You need to share photos of your project.
post Mar 28 2026, 09:01 AM
Welcome!
I know you've already used this forum for research but it sounds like you'll be doing more. I find using this link yields good results: https://cse.google.com/cse?cx=0024083458981...772:ajvfxschcgc
post Mar 28 2026, 10:02 AM
Great to have you aboard, post pics when you are able
looking forward to seeing this example
I had an original 356SC in Irish Green years ago, one of the ones that got away
post Mar 28 2026, 10:20 AM
I would pull the glass. Otherwise, welding and grinding sparks will damage it. The back glass usually needs to be resealed anyway.
campbellcj
post Mar 28 2026, 10:31 AM
I can't Re Member
(IMG:style_emoticons/default/welcome.png) I agree I would pull out and store the glass and other trim or interior bits that could get damaged during resto work.
My car has a 10-point welded cage and yes there are large reinforcing plates welded to the longs and other parts of tub where the cage tubing attaches.
bkrantz
post Mar 28 2026, 08:16 PM
Uh oh. Do you think we scared him off? (IMG:style_emoticons/default/confused24.gif)
krazykonrad
post Mar 29 2026, 05:54 AM
(IMG:style_emoticons/default/welcome.png) Welcome to the club!
post Mar 29 2026, 09:03 AM
Hey nice rack! -Celette
Ambitious project. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
TACAN73
post Mar 29 2026, 01:13 PM
Wow. Hello!
Here's a couple of pics. More to follow, it didn't occur to me to document at first:
That's L30E Bahia red under the Green. Note the bolt heads. First aha moment with this car. Next were these plates on the passenger long. Hmm.
After reading up on rust issues I went looking, and oh boy, did I find them. I tried the
passenger side jacking point and it folded in immediately. The top side (right where it bends upwards) was gone. I began to strip out the interior. Turns out it has two floors on the passenger side: a solid floor made out of galvanized sheet metal and about 75% of the original floor left. It's not a patch but a full sided pan on the right. Curious as the welding for the floor is really nice, but the material is like HVAC ducting stock. dead soft and not a stiffening rib in sight. This was the decision point for taking it off the street and a full teardown.
Tonyooc
post Mar 29 2026, 04:18 PM
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/piratenanner.gif)
post Mar 29 2026, 10:28 PM
QUOTE(TACAN73 @ Mar 29 2026, 12:13 PM) *
Interesting stiffening kit... Must be hiding something... (IMG:style_emoticons/default/sad.gif)
seanpaulmc
post Mar 30 2026, 07:00 AM
Build the rotisserie. You'll have so much more freedom with the repairs that car needs.
https://www.youtube.com/watch?v=ZiGB_MHBbls
http://www.914world.com/bbs2/index.php?sho...209540&st=0
You will see in Fred's LE resto thread he is using it. He's smart.
After years of working on my back in the driveway with jack stands limiting access, I know this type of rotisserie with save you considerable time with the metal repairs you have ahead.
More pictures!
TACAN73
post Mar 30 2026, 08:28 PM
It seems I have a rotisserie in my future, but one step at a time. I am still in the part of the project car curve where the delta between the imagined state of the chassis and actual condition is increasing. What makes this interesting is that I am clearly not the first person to work on this thing. Here's the floor- see if you can spot where the patch panel is visible underneath the original floor. Both are rusting as it turns out:
Some PO put a lot of work into this - note the number of individual patch panels tacked into the driver side floorpan-which seems to be a replacement piece as there is no tar.
But overall, the body is in good shape and the doors open-thought the passenger side is a bit tight:
Driver side works great:
And still more surprises:
Next step is inventory.
- Lo-Fi Version Time is now: 14th August 2026 - 08:45 PM
