| TonyA |
Mar 24 2026, 01:12 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 666 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
Does the wire from the oil temp at the taco plate go directly to the gauge in the center console? Or is there a connection i am missing in harness somewhere past the snorkel?
1974 2.0 with center console gauges. |
| Ron914 |
Mar 24 2026, 01:46 PM
Member ![]() ![]() Group: Members Posts: 490 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Does the wire from the oil temp at the taco plate go directly to the gauge in the center console? Or is there a connection i am missing in harness somewhere past the snorkel? 1974 2.0 with center console gauges. My wire connected to the console gauge at a single spade connector near the battery down where the fuel lines come into the engine compartment. |
| wonkipop |
Mar 24 2026, 01:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,468 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
info is all here.
from horses mouth @JeffBowlsby http://www.914world.com/bbs2/lofiversion/i...hp?t244721.html |
| Dave_Darling |
Mar 24 2026, 05:46 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,334 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The wire from the sender goes across the front of the motor (behind the fan shroud) to a connector over in the neighborhood of the battery. From there, it goes into the snorkel and into the center tunnel, to another connector below the center console. From there, another wire takes it to the gauge--whether that gauge is in the console, or up in the combo gauge on the dashboard. (That last is pretty uncommon.)
--DD |
| wonkipop |
Mar 24 2026, 06:30 PM
i believe this is the wire you are looking for @TonyA
black and green. has a plastic socket protection cap. around the battery lying on the engine shelf. |
| TonyA |
Mar 25 2026, 06:51 AM
Thanks guys
Lo-Fi Version | Time is now: 25th March 2026 - 08:42 AM |
