> Installing alternator air bellows?
SKL1
post Mar 24 2026, 10:40 AM
So what is the trick to installing the rubber bellows for air flow to the alternator?
Trying to snake that into that tight spot with the clip inside seems nearly impossible. What am I missing?? Trying to put that in before installing my rebuilt alternator. Got a new one from 914rubber...
TIA.
post Mar 24 2026, 11:50 AM
Clip goes in AFTER you put the boot in.
SKL1
post Mar 24 2026, 03:36 PM
Thanks. Got it in place without it and wondered the same thing... learn something every day, even after 55+ years playing with these things!!
Dave_Darling
post Mar 24 2026, 05:31 PM
914 Idiot
I wouldn't want to try it with the engine in the car!
I remember having the fan shroud split when I installed the boot. Made access really simple.
--DD
SKL1
post Mar 24 2026, 09:12 PM
You mean like this??? Yeah, not a lot room to work, even with the car on a lift!!Attached Image
frank_c
post Mar 24 2026, 10:55 PM
I could not get the replacement boot from 914 Rubber to fit quite right. I purchased the correct clip for the boot that fits inside the fan housing, but once I pivot the alternator to tighten the belt, the boot leaves a gap as shown in the photo. Are others experiencing this as well?
jvmarino
post Mar 25 2026, 05:04 AM
QUOTE(frank_c @ Mar 24 2026, 11:55 PM) *
I had same issue with my boot. Seems there were 2 different diameter boots made and mine was the larger. The boot from 914Rubber is the smaller diameter one. Unfortunately I ripped old hardened boot up when taking it out, so had to make do with the imperfect fit.
1 Members: frank_c
- Lo-Fi Version Time is now: 25th March 2026 - 08:42 AM
