| mskala |
Mar 23 2026, 03:31 PM
R ![]() ![]() ![]() Group: Members Posts: 1,938 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I see quite a few places are making lower valve covers for 911 that are like the 964
and use the o-ring style gasket and seem like they would be easy to keep from leaks. But, I have never heard of anybody installing these on the 914. I don't know if the height is such that part of it would require machining to get them off past the suspension points. Anybody gone this route? Thanks Mark S. '70 914-6 (engine being rebuilt) |
| T.Rick6 |
Mar 23 2026, 04:58 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States
Good question, I have them installed on my 3.3, looks to me you may be able to remove 10mm from the studs and it should work. My engine is not installed so no proof of concept. I was looking for pictures of the valve cover to ear to determine if I could go coil on plug. Here’s a shot of mine if that helps. Todd
| T.Rick6 |
Damn, it’s upside down!..
| 73-914 |
Mar 23 2026, 05:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 666 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None
| sixnotfour |
Mar 23 2026, 06:52 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,172 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| mskala |
Mar 23 2026, 07:37 PM
Thanks. It's really hard to know from pics, maybe someone will need to be the
guinea pig and try it. Which brand are those? I think there are several types that are similar. Are those the regular studs? They look pretty long. |
| fixer34 |
Mar 23 2026, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,403 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
With those long studs, I don't think you could get the original covers off, let alone with these. If you want to go this route, bite the bullet and plan to drop the engine/trans when doing an oil change/valve adjustment.
| T.Rick6 |
Mar 24 2026, 10:24 AM
The valve covers are Terrett Engineering. Yes the studs are stock but will be replaced with the 964 studs (6x25 Mpn 999-062-127.03) @ 5.41ea X 24 (2 extra) is 130 bucks, hard to swallow that amount for studs, looking elsewhere. (IMG:style_emoticons/default/beerchug.gif)
mskala |
| mskala |
Mar 24 2026, 11:30 AM
Thanks for the info. They have a fighting chance of fitting or only needing machining
in a small area, they appear shorter than 930 covers. My engine is not together and in the car, but the shortest part of the 930 covers I've previously ground down is 3/4" high. Note that you need 8mm studs, not 6mm, so don't buy 964 studs. Mark S. '70 914-6 |
| rgalla9146 |
Mar 24 2026, 05:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,947 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I don't know the cost of the aftermarket covers but do know I got a pair of OEM
for $60. I had them machined for clearance as needed, opened the stud holes to 8mm and installed studs that protrude 24 mm above the surface. Easy removal, engine in place. Total cost $160 Perfect for my 12 plug 3.2 Attached thumbnail(s) |
Mar 24 2026, 06:53 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,566 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The valve covers are Terrett Engineering. Yes the studs are stock but will be replaced with the 964 studs (6x25 Mpn 999-062-127.03) @ 5.41ea X 24 (2 extra) is 130 bucks, hard to swallow that amount for studs, looking elsewhere. (IMG:style_emoticons/default/beerchug.gif) mskala We are going to be making our own studs soon. Already sent out some Porsche studs for testing so we can be sure we have them made as good as stock. It's difficult to get the right size stud, plated and in quantities for a reasonable price so we decided to get it done and have enough for us and probably sell retail as well. Thinking pre made engine kits. |
Lo-Fi Version | Time is now: 25th March 2026 - 08:42 AM |
