| mcericmc |
Mar 15 2026, 10:43 AM
Newbie ![]() Group: Members Posts: 14 Joined: 30-June 21 From: Texas Member No.: 25,681 Region Association: None |
I could use some help with a DPD aftermarket A/C system I bought years ago, but never got around to installing because of my wife's health problems. I live in Texas, so A/C is a necessity during the 8 months of summer here.
I'm looking for pictures of the compressor mounted to the engine and pictures of the mounting bracket. I think I might be missing part of the bracket itself. I realize how slim the chances of finding any info is since these systems were kind of rare, but any help or leads to information would be greatly appreciated. Thanks. |
| Literati914 |
Mar 15 2026, 12:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,226 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm not sure if this is the DPD system or which it may be..
It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). Attached image(s)
| Ninja |
Mar 15 2026, 02:28 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
That is the first decent side mount system I've seen.
It's using a drop-dead dependable Sanden compressor, and it's driven by a serpentine belt. I'd use that in a heartbeat and I'm a picky anal bitch! For those who don't know I run an Automotive AC specialist shop in Granbury Texas. That is what I would have built had I decided to stay T4. That looks NICE!!!! (IMG:style_emoticons/default/ninja.gif) |
| 914Sixer |
Mar 15 2026, 02:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,436 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
There was another version that used a top mount where the later air pump mount was. No sheet metal cutting in engine compartment. No pictures though
DLee makes AC kit |
| mcericmc |
Mar 15 2026, 05:36 PM
I'm not sure if this is the DPD system or which it may be.. It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). Thank for the diagrams. I'm in the Northeast Dallas area. Definitely interested in the Bracketry. I can't travel though because my wife is disabled. |
| Literati914 |
Mar 15 2026, 07:13 PM
I'm not sure if this is the DPD system or which it may be.. It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). Thank for the diagrams. I'm in the Northeast Dallas area. Definitely interested in the Bracketry. I can't travel though because my wife is disabled. Posting a pic of the brackets that you do have, would probably be helpful. |
| Chris914n6 |
Mar 15 2026, 08:36 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,527 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It used the off-the-shelf Sanden mount with a couple pieces welded on to mount to the fan shroud. It uses a custom machined pulley extension that bolted to the crank/fan like the smog pump setup.
My understanding is the modern Sanden comp is small enough to not need the body side shroud/seal cut into. There was another version that used a top mount where the later air pump mount was. No sheet metal cutting in engine compartment. No pictures though DLee makes AC kit |
| friethmiller |
Mar 16 2026, 10:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
I have an older DLee-sourced top mount bracket that I welded together for my Sanden 508. His more recent mounts look to be more sturdy, which I think it needed. Two things I can tell you about this mount 1) it works great, no cuts; 2) the bolts will rattle out if you don't use locktite (yes, I'm a dumbass (IMG:style_emoticons/default/headbang.gif) ). @Ninja commented on this when he worked on my system a while back. I later discovered the issue when I pulled my engine. I plan to tap a larger diameter bolt into the air shroud up front and might modify the mount to make it a bit more secure.
| Ninja |
Mar 16 2026, 11:01 AM
Fred's top mount was "floppy" at idle. You could see stuff moving!
I'd worry about what it was doing at full steam 3500 RPM... I think the problem is limited by good mounting points on the top of the engine. When designing compressor mounts expect 5 HP worth of stress. The normal side mount position has much meatier mount locations. Now, the normal mount position places the compressor for reverse rotation, the old York style didn't care about direction. Many compressors are specific regarding rotation due to thrust bearing orientation. That Sanden is not. Most compressors will actually function driving them backwards, the touchy ones will die EARLY! (IMG:style_emoticons/default/ninja.gif) Edit: The pic above shows a standard direction mounted Sanden. I'm not sure there is enough room in a 914, especially for a standard (full size) Sanden. I was planning a smaller version Sanden mounted on the original York mount (as a base/modified) and staying reverse rotation. |
| mcericmc |
Mar 16 2026, 11:13 AM
I have an older DLee-sourced top mount bracket that I welded together for my Sanden 508. His more recent mounts look to be more sturdy, which I think it needed. Two things I can tell you about this mount 1) it works great, no cuts; 2) the bolts will rattle out if you don't use locktite (yes, I'm a dumbass (IMG:style_emoticons/default/headbang.gif) ). @Ninja commented on this when he worked on my system a while back. I later discovered the issue when I pulled my engine. I plan to tap a larger diameter bolt into the air shroud up front and might modify the mount to make it a bit more secure. ![]() What a NICE RIG! Unfortunately for me, I'm still using the fuel injection so it won't fit. I've been leaning toward dual Webers though. Did you have to modify the engine to use the them (a new cam or anything)? Where would I get a DLee-sourced top mount bracket? Thanks for you post and the photo! |
| mcericmc |
Mar 16 2026, 11:21 AM
I'm not sure if this is the DPD system or which it may be.. It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). Thank for the diagrams. I'm in the Northeast Dallas area. Definitely interested in the Bracketry. I can't travel though because my wife is disabled. Posting a pic of the brackets that you do have, would probably be helpful. This is the compressor and what's left of the bracket. The rest of it must have gone with whatever car it was on. Attached thumbnail(s) |
| friethmiller |
Mar 16 2026, 12:05 PM
Where would I get a DLee-sourced top mount bracket? Here's the classic thread that Doug created on A/C systems. You can pm him directly or through his "Rusty Acres" business (see signature line in his first post) Doug's A/C System, R&D/Build Thread |
| mcericmc |
Mar 16 2026, 03:47 PM
Where would I get a DLee-sourced top mount bracket? Here's the classic thread that Doug created on A/C systems. You can pm him directly or through his "Rusty Acres" business (see signature line in his first post) Doug's A/C System, R&D/Build Thread WOW! Fantastic and just what I was looking for. Thanks. It's going to take a while to digest the information. (IMG:style_emoticons/default/piratenanner.gif) |
| mcericmc |
Mar 17 2026, 10:08 AM
I'm not sure if this is the DPD system or which it may be.. It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). How much would you want for the bracketry? I noticed you listed Dallas in your profile. I live in Rowlett. |
| majkos1 |
Mar 17 2026, 01:33 PM
Member ![]() ![]() Group: Members Posts: 262 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
couple shots of what I have, |
| mcericmc |
Mar 17 2026, 05:04 PM
| Dave_Darling |
Mar 17 2026, 07:00 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,331 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I'm not sure if this is the DPD system or which it may be.. In the 914, the compressor was mounted on the other side of the engine This shows it on the driver's side (914 orientation), while both the VPC and DPD kits mounted it on the passenger's side of the engine. --DD |
| mcericmc |
Mar 18 2026, 12:34 PM
I'm not sure if this is the DPD system or which it may be.. It gives a descent over view though. I believe I still have original aftermarket bracketry that I'm not gonna be using, if you need something (in Texas too). I'm interested in the bracketry. Not having much luck. Looks like I'm kind of late to the party. DLee hasn't posted anything since 2022. |
| Dlee6205 |
Mar 18 2026, 01:38 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
I'm interested in the bracketry. Not having much luck. Looks like I'm kind of late to the party. DLee hasn't posted anything since 2022. I lost my account around that time and was unable to recover it. (IMG:style_emoticons/default/sad.gif) I still have some inventory collecting dust. These would mount via the provisions for a Smog pump and is a much better method from my earlier versions. http://www.914world.com/bbs2/index.php?sho...=375217&hl= I’ve also had a mount designed and created that would place the compressor underneath the engine tin on the passenger side similar to the dealer locations but would require no cutting. I’m waiting on the right test mule for that setup. |
Lo-Fi Version | Time is now: 18th March 2026 - 08:18 PM |
