| 914rrr |
Mar 14 2026, 08:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,033 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
Finally getting somewhat settled enough in my new workshop / mancave in McMinnville, TN to FINALLY do some work on the teener. Just from setting in place for 3-ish weeks made a pretty big oil leak mess. Oil was dripping out of both oil, temp plate bolts.
After cleaning up the mess, I figured I'd try backing one of the bolts out to inspect the washer / crush ring. Turns out the DAPO used steel split lock washers instead !!! (IMG:style_emoticons/default/slap.gif) I reinstalled the bolts one at a time with the copper crush rings and it completely cured my oil leak! (IMG:style_emoticons/default/aktion035.gif) Pic of offending washers and new crush rings installed on the bolts below. ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 07:24 AM |
