> Re-seal Engine after Clean Up
Literati914
post Mar 13 2026, 01:37 PM
I removed the engine tins from my 1.7 to clean and paint, while also degreasing the engine and transmission. I'm thinking I'll re-seal anything that's convenient to do-so while I'm here. There was an accumulation of baked on oil under the tins on top of the cylinders, not so much under (oil return tubes seem fairly well sealed and clean).. what does that usually imply, if anything?
post Mar 13 2026, 02:45 PM
In general, just normal for an air cooled engine.
bkrantz
post Mar 13 2026, 07:42 PM
Check the cork seal under the oil filler "tank".
Oil on top of the engine can also come from sloppy pouring.
Literati914
post Mar 13 2026, 09:28 PM
OK, I'll check that cork seal, thanks.
The oil is (on top) closer to the block end tho... cylinder to block seals maybe? I'll check head bolt torques, maybe they've loosened over time.
- Lo-Fi Version Time is now: 14th March 2026 - 03:20 AM
