| Flyinlow |
Mar 12 2026, 05:51 PM
Flyinlow ![]() ![]() Group: Members Posts: 127 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Hi.. what would be a reason why my generator light stays on when running?1974 2.0 T.I.A. Dennis
Mar 12 2026, 06:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,475 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Could be as simple as a slipping belt or failed voltage regulator. Or more complicated, bad wires and ground issues with the alternator or failed alternator.
| Flyinlow |
Mar 12 2026, 06:58 PM
Thanks I’ll keep checking. Dennis
| Dave_Darling |
Mar 13 2026, 12:20 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If the tach also doesn't read, it's fuse #8.
--DD |
| Flyinlow |
Mar 13 2026, 07:44 AM
| Spoke |
Mar 13 2026, 11:46 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,353 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Hi.. what would be a reason why my generator light stays on when running?1974 2.0 T.I.A. Dennis Did this just start happening? Is the belt on and tight? With the engine running, measure all 3 wires for the alternator at the relay board connector to chassis ground. This will tell a lot of what is going on. D+ should be 14V DF should vary between 4-9V D- should be zero Vbattery should be 14V |
Lo-Fi Version | Time is now: 13th March 2026 - 02:56 PM |
