> Oil pressure switch removal tricks
TonyA
post Mar 10 2026, 04:28 PM
Nachmal
Is there a special way to remove an oil pressure switch on a 2.0. I am worried that i may drop it behind the tin.
post Mar 10 2026, 05:32 PM
Interesting - I took mine out and replaced it with a hose for a remote "block" in order to use both a sender for the idiot light as well as one for a gauge. I think it's a 24mm - but I don't remember anything special to avoid dropping it behind the tin....maybe i just got lucky?
Shivers
post Mar 10 2026, 07:02 PM
QUOTE(TonyA @ Mar 10 2026, 03:28 PM) *
If I can not find my spark plug socket, I will use a strip of cardboard from the spark plug box and wedge the plug into the socket. You can remove them the same way. Just a thought
2 Members: dhuckabay, jfs911
- Lo-Fi Version Time is now: 10th March 2026 - 07:03 PM
