| seanpaulmc |
Mar 9 2026, 11:41 AM
Member ![]() ![]() Group: Members Posts: 424 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
I picked up a stock rear sway bar for my project and it had some old bushings still on it. Here they are pictured with a new set of OEM style from 914Rubber.
Questions: 1. Anyone recognize the material of the old bushings? 2. The new ones don’t seem to have a split. Is it on me cut them for installation? 3. Is there a recommendation for lubrication with the new bushings? Thanks |
| Front yard mechanic |
Mar 9 2026, 02:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
I would use the old ones goodyear welt but I’m a tight wad
| porschetub |
Mar 9 2026, 08:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Depends if the uncut ones with slip over drop link ends each side not sure if they will as mine are cut but worth trying ,cheers
| bdstone914 |
Mar 9 2026, 08:50 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I picked up a stock rear sway bar for my project and it had some old bushings still on it. Here they are pictured with a new set of OEM style from 914Rubber. Questions: 1. Anyone recognize the material of the old bushings? 2. The new ones don’t seem to have a split. Is it on me cut them for installation? 3. Is there a recommendation for lubrication with the new bushings? Thanks 1. Rubber. Don't know why they as speckled 2. Yes slit them 3 no lube needed |
Lo-Fi Version | Time is now: 10th March 2026 - 01:46 AM |
