| Steve1956 |
Mar 8 2026, 07:54 PM
Newbie ![]() Group: Members Posts: 31 Joined: 4-November 22 From: Morocco,Indiana Member No.: 26,966 Region Association: None |
| Unobtanium-inc |
Mar 8 2026, 07:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,436 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None
You can start a drum beat right where the latch is, that sometimes works. Also, spraying WD into the crack can help. As a last resort you can sawzall under the hood through the latch itself.
| Ishley |
Mar 8 2026, 08:44 PM
Member ![]() ![]() Group: Members Posts: 326 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Take the front bumper off. 2 bolts on each side up in the wheel well. Then there is a hole you can put a screwdriver thru to push the latch to open. It’s pretty easy to do.
| Montreal914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,051 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Before going into the cutting solution, isn't there a way to open the hood by removing the front bumper? (IMG:style_emoticons/default/idea.gif)
| dtmehall |
Mar 8 2026, 08:59 PM
Member ![]() ![]() Group: Members Posts: 252 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
| 914sgofast2 |
Mar 8 2026, 10:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 794 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Take off the front bumper. 2 bolts are in each of the front fender wells. Then look for the rubber plug in the center of the body behind where the front bumper was mounted. Take out the plug and stick a flat screwdriver into the whole and fiddle around with the latch release until the hood magically pops open for you. Sounds like the hood cable has broken or become disconnected from the latch itself and isn't releasing the latch's mechanism.
| Dlee6205 |
Mar 8 2026, 11:22 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
This is a late car… there are no bumper bolts in the wheel wells. There’s two bolts on the underside that attach the bumper to the bumper shocks. But otherwise yes, remove the front bumper and find the access hole to manually pop the latch.
| infraredcalvin |
Mar 8 2026, 11:36 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,729 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
This is a late car… there are no bumper bolts in the wheel wells. There’s two bolts on the underside that attach the bumper to the bumper shocks. But otherwise yes, remove the front bumper and find the access hole to manually pop the latch. (IMG:style_emoticons/default/agree.gif) BUBs Have you tried using 2 people, one to pull the handle, the other to coerce the hood open, it could just be stuck to whats left of the rubber seal… |
| bdstone914 |
Mar 9 2026, 03:35 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
First travel someone press down on the cemetery of the hood above the lock while you pull the handle. Tie a loop of rope around the lock handle and put your wrist thru the loop to be able to pull harder.
If the fails remove the bumper and trip the lock eith a small screwdriver. No need to cut anything |
| Shivers |
Mar 9 2026, 04:12 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,313 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| billh1963 |
Mar 9 2026, 08:08 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,428 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Mar 9 2026, 08:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,525 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Take the front bumper off. 2 bolts on each side up in the wheel well. Then there is a hole you can put a screwdriver thru to push the latch to open. It’s pretty easy to do. (IMG:style_emoticons/default/agree.gif) |
| Steve |
Mar 9 2026, 09:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,025 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
(IMG:style_emoticons/default/agree.gif) Bubs do not have the two bolts in the fender well. The bumper shocks mount in the trunk. You remove the bumper from underneath the bumper. Then you can access the hole to pop the trunk.
| Steve1956 |
Mar 9 2026, 09:52 AM
Hi,bought this parts car last weekend,it's a1976 2.0lt car. Can't get the front trunk to open. The release works as it should but won't pop the hood. Any ideas? Thank you for all the helpful comments. I had planned on disassembling the entire car and using some parts on my other car. I'll update when the trunk lid is open. |
Lo-Fi Version | Time is now: 10th March 2026 - 01:46 AM |
