> Exterior Door Handle Options?
75ninefourteen
post Mar 5 2026, 01:12 PM
My Driver's side exterior door handle is shot and trying to source a replacement without having to buy with a new lock cylinder (would like to stay to a single key).
I've tried one from 914Rubber and Sierra Madre collection. Neither one worked due to the fact the hole for the lock cylinder is too small. Did a quick search here and saw a comment not to buy the reproduction handles for that reason. I've also looked some on eBay and all the used ones are broken or are the repos.
I thought a saw one that no longer used the lock cylinder and converted to a push button, but can't seem to find that now.
Has anyone had luck with ordering a new door handle recently?
TIA.
post Mar 5 2026, 01:58 PM
Contact Kurt Curt our lock resident expert. He will set you up. (IMG:style_emoticons/default/sunglasses.gif)
@thecabinetmaker
DC_neun_vierzehn
post Mar 5 2026, 03:41 PM
QUOTE(Montreal914 @ Mar 5 2026, 02:58 PM) *
Contact Kurt our lock resident expert. He will set you up. (IMG:style_emoticons/default/sunglasses.gif)
@thecabinetmaker
He has new handles w/o cylinders. You can transfer your cylinder to your new handle. I did it recently.
sb914
post Mar 5 2026, 03:46 PM
Surf Guru
https://www.914locks.com
URY914
post Mar 5 2026, 06:27 PM
I built the lightest 914 in the history of mankind.
What do you mean by "shot"? What is wrong with it?
post Mar 5 2026, 07:05 PM
Buy a good used one from a member here, transfer the lock core, done.
TheCabinetmaker
post Mar 5 2026, 07:06 PM
I drive my car everyday
QUOTE(75ninefourteen @ Mar 5 2026, 02:12 PM) *
TIA.
Hi. Please contact me at 914locks@gmail(dot)com
My handles will fit. I have both used and newly chromed
Curt
post Mar 5 2026, 09:15 PM
lighten em
......(IMG:style_emoticons/default/beer3.gif)
75ninefourteen
post Mar 5 2026, 10:53 PM
QUOTE(URY914 @ Mar 5 2026, 06:27 PM) *
The actual handle is snapped into 2 pieces. And on the back side the mounting bracket and part of the back side have broken off. It was broken when I bought the car and figured it would be an easy part to replace. I will post some pics tomorrow when I get a chance.
Thanks for all the responses and I will reaching out @thecabinetmaker .
JamesM
post Mar 6 2026, 12:14 AM
QUOTE(75ninefourteen @ Mar 5 2026, 09:53 PM) *
Refurbished by Curt or new from Porsche, at least if you want the lock to actually work. All the new aftermarket handles (that come from the same source no matter the vendor) have issues with the lock cylinder fitment.
75ninefourteen
post Mar 6 2026, 11:37 AM
This is why I need a new handle.
post Mar 6 2026, 01:59 PM
Gotta keep everything lubed up or the flap breaks off when you pull really hard.
URY914
post Mar 6 2026, 06:22 PM
The mounting tab can be fixed if broken.
914sgofast2
post Mar 6 2026, 08:28 PM
When you get the replacement handle, do yourself a favor and remove the actual latching mechanism from inside the door and soak it in some arts cleaner to clean out 50 years of accumulated and hardened grease and dirt. Then oil the latch mechanism and re-install into the door. You can now enjoy a door that opens and locks/unlocks easily without putting a strain on your newly replaced outside door handle. When I did this to my 914, I was amazed at how easily the outside door handle locked and unlocked the door.
post Mar 6 2026, 11:25 PM
QUOTE(914sgofast2 @ Mar 6 2026, 08:28 PM) *
100% (IMG:style_emoticons/default/agree.gif)
i fully serviced my door handles and mechanisms last year.
the doors open using my finger tiips.
effortless. i was transported back to 1989 when i first bought the car.
thats how it was.
well worth the effort to lube and grease everything in there.
do the window winders, the door stay mechanism, the works. (IMG:style_emoticons/default/beerchug.gif)
@mepstein is pointing to the same advice. words of wisdom.
post Mar 7 2026, 06:11 AM
QUOTE(wonkipop @ Mar 7 2026, 12:25 AM) *
thats how it was.
Lube up the window winder mechanism and rails, cable pulls for the lids, seat rails, interior door latches, pivots on the wiper motor mechanism, etc. it transforms the car.
TheCabinetmaker
post Mar 7 2026, 07:25 AM
QUOTE(914sgofast2 @ Mar 6 2026, 09:28 PM) *
Thank you go fast. This is the#1 reason that door handles break.
post Mar 7 2026, 08:44 AM
QUOTE(TheCabinetmaker @ Mar 7 2026, 08:25 AM) *
I broke one on my first 914 back in college. Definitely because I was pulling on it too hard when it got stiff. The flaps are basically chromed pot metal.
campbellcj
post Mar 7 2026, 10:03 AM
I can't Re Member
Ahh, the infamous "pinggggg" inside your door that goes along with 914 ownership at some point. I've repaired as well as replaced and rekyed them before.
Minor hijack - If anyone is selling drilled lightened handles I would love a set. Obviously more for the aesthetic vs saving an ounce or whatnot but it would look cool. (I already have no lock cylinders, windows, or fancy door panels in terms of door lightening)
porschetub
post Mar 7 2026, 12:54 PM
QUOTE(URY914 @ Mar 7 2026, 01:22 PM) *
my car had that repair done on both handles when I bought it , works very well , right side one had spots in the chrome so I bought a perfect chrome replacement one for very cheap on Ebay as it had crack on in the rear tab and I snapped it off by hand .
Pot metal just isn't strong enough when the latches are semi seized .
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
2 Members: campbellcj, chmillman
- Lo-Fi Version Time is now: 7th March 2026 - 03:35 PM
