| Mr.Vman |
Mar 3 2026, 01:30 PM
Newbie ![]() Group: Members Posts: 28 Joined: 1-October 24 From: Sierra Vista, AZ. Member No.: 28,388 Region Association: Southwest Region |
!976 914, 2.0 engine T4, 80,000 mile car. Engine apart, excessive flywheel thrust and oil leakage from everywhere. Question on crankshaft thrust. The thrust bearing surface is worn to a knife edge. Is there a measurement from back of case to case bearing surface? Is this where the possible; "cutting the thrust" happens? In Arizona, Tucson, Phoenix or? Is there a shop for good case machine work? The bearing faces look good. Appears engine has never been apart before. Bottom line, how to know if case is not worn at thrust area, and is repairable? Center main bearing insert had crush. Not sure about line bore yet. Thank you in advance. Mr.Vman
Mar 3 2026, 02:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Type IV motors don't have the issues Type 1s have with saddle wear on main bearings. Line boring isn't needed as often on Type IVs, but it still occurs. Measure things before assuming a line bore or other machine work is needed on your case. Guessing that end play on your motor wasn't right or a heavy clutch caused excessive wear on the thrust surface? Careful measurement, the right parts, mockups and assembly should get you where your motor needs to be. Best wishes for a successful fix!
Here's a discussion about measuring the main bearing saddle on a Type IV motor: https://www.thesamba.com/vw/forum/viewtopic.php?t=544913 Here's a tool to measure main bearing saddles (others are available), but many of us use a bore gauge/tool: https://www2.cip1.com/c31-012-140-105g4/ |
Mar 4 2026, 10:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,521 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
wondering why the thrust face is worn soo much? What forces are creating that?
I have never seen this before (IMG:style_emoticons/default/idea.gif) |
Mar 4 2026, 12:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,732 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
No mention of crank end play or shims?
Without end play set properly there will be massive thrust bearing wear. |
| Chad911sc |
Mar 5 2026, 11:42 AM
Member ![]() ![]() Group: Members Posts: 273 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
That’s what I was thinking as well. If the end play had above the .005 max end play from the start, it would beat itself to death over that much time causing the thrust bearing to be flattened out.
| brant |
Mar 6 2026, 10:38 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,156 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I would also guess who ever built it last time didn’t set this correctly
How many washers did you take out? I think it has to be combination of 3 They sell different thickness of these washers and it has to be correct total thickness to needed spec Wondering what else was damaged internally from the play Your going to need some new parts |
Lo-Fi Version | Time is now: 7th March 2026 - 03:34 PM |
