| pbanders |
Feb 26 2026, 11:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 989 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Example of using Perplexity to understand how the MPS operates. Not perfect, but gives you an idea of what can be done.
https://www.perplexity.ai/search/how-does-t...ue3_8lIh9rqNQ#2 This was the query: "How does the pressure sensor used in the Bosch D-Jetronic fuel injection system work? Be detailed in describing how it operates at idle, part-load, and full-load conditions." To improve on the quality of the response, you can combine Perplexity with NotebookLM to cherry-pick the sources you want to use for the topic. This prevents unreliable sources being used, and extends the types of sources. This concept can be used for a huge number of topics. |
Feb 26 2026, 12:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,732 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I know AI is unstoppable . . .
But it is hilarious that it’s just scraping jetronic.org and that you have to coach it. Frankly it should also be scraping your site. Interesting attempt though. (IMG:style_emoticons/default/beerchug.gif) |
| worn |
Feb 26 2026, 08:23 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Example of using Perplexity to understand how the MPS operates. Not perfect, but gives you an idea of what can be done. https://www.perplexity.ai/search/how-does-t...ue3_8lIh9rqNQ#2 This was the query: "How does the pressure sensor used in the Bosch D-Jetronic fuel injection system work? Be detailed in describing how it operates at idle, part-load, and full-load conditions." To improve on the quality of the response, you can combine Perplexity with NotebookLM to cherry-pick the sources you want to use for the topic. This prevents unreliable sources being used, and extends the types of sources. This concept can be used for a huge number of topics. I am impressed. I have to say though that this is one of the biggest challenges I have seen for AI. Compared to the writing of selfless engineers such as some unknown Anders, the description seems a bit, well a bit lame. I am certain that the processors sweated bullets trying, but the bar (or Torr or some such measure) is set awfully high. |
| JeffBowlsby |
Feb 27 2026, 10:53 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,200 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Big big concern is with AI locating and circulating inaccurate, bogus, even corrupt information. GIGO. It has no ability to evaluate data, just regurgitate what it finds.
| pbanders |
Mar 9 2026, 11:34 AM
Big big concern is with AI locating and circulating inaccurate, bogus, even corrupt information. GIGO. It has no ability to evaluate data, just regurgitate what it finds. That's what NotebookLM addresses. You get to select the sources, it's not like a typical chatbot search, that goes against the full training corpus. |
Lo-Fi Version | Time is now: 10th March 2026 - 01:46 AM |
