| cabrioartie |
Feb 21 2026, 06:48 PM
Newbie ![]() Group: Members Posts: 17 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
My mechanic recently replaced my CHT and used electrical tape over the spade connectors which I find unacceptable.
I assume there should be a spade housing covering the connectors like so many other places around the engine. I've searched, but haven't found the part. Does anyone know if they are still make it (and the part number) or where I can find a similar housing to use? |
| Literati914 |
Feb 21 2026, 07:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,209 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Feb 21 2026, 07:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,716 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Yup . . . Lazy mechanic beware. (IMG:style_emoticons/default/chair.gif)
If you want OEM connector place WTB in classified - someone can probably come up with one. If you’re not hooked into OEM there are parts like this available commercially. Wiringdepot.com, granger, McMaster Carr, etc are likely sources |
Feb 21 2026, 07:19 PM
(IMG:style_emoticons/default/agree.gif) This and probably easier to source than my recommendation that may force larger quantity purchase. |
| cabrioartie |
Feb 21 2026, 08:08 PM
Sorry, I don't know if it's just my car, (but it does look original) but the car's wiring harness end is a male connector and this male spade seems very long too, only the CHT end is a female connector.
So, I would need one of these with a female and male on each end. |
| JeffBowlsby |
Feb 21 2026, 10:27 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,193 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Hey Artie, I have just what you need. PM me your address and I’ll get it right out to you.
Feb 21 2026, 11:51 PM
Hey Artie, I have just what you need. PM me your address and I’ll get it right out to you. (IMG:style_emoticons/default/smilie_pokal.gif) |
| chmillman |
Feb 22 2026, 12:22 PM
Member ![]() ![]() Group: Members Posts: 350 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
There are a few of these in various locations around the car, two triples up front by the headlight motors...
I did have a bit of a hard time finding them here at first, I finally bought some in Germany via eBay... Then later I did find some suppliers here, but what I already bought in DE is probably a lifetime supply. I like the fully transparent ones because you can see the condition of the connectors inside. You can cut the 12x strips apart into singles, doubles etc. ![]() |
Feb 22 2026, 12:43 PM
With all credit going to JeffBowlsby - he will have the proper connector.
As the OP noted, the picture I posted of a double male spade isn’t correct. The CHT sensor is a female spade and the harness side connector / insulator is only a single spade. If I recall correctly (?? Questionable) the wiring harness side is a male spade that gets crimped to the harness and the the spade is inserted/locked into the plastic insulator. Regardless, there are multiple ways the mechanic could have done something better than using electrical tape but I’m sure Jeff will get him set up properly. |
| cabrioartie |
Feb 22 2026, 01:41 PM
Agree with your statement about there are better ways than electrical tape. Frankly I was very surprised when I saw this. Funny thing is (maybe not funny), I only took it to a mechanic because of personal time related issues and problems getting it SMOGed so I could register it.
Now I've doing the work myself and cleaning things up. Jeff has said he has exactly what I need and will be sending it out. Which I appreciate immensely. This will then close out one thing which needs to be rectified in a long line of things which need to be fixed. |
Feb 22 2026, 02:09 PM
Now I've doing the work myself and cleaning things up. (IMG:style_emoticons/default/aktion035.gif) Almost always the better plan vs paying someone to learn about 914’s on your car. My philosophy is if someone is willing to do shoddy work on something you can see, imagine what they will do if only they know what has been done. |
| chmillman |
Feb 23 2026, 10:15 AM
With all credit going to JeffBowlsby - he will have the proper connector. As the OP noted, the picture I posted of a double male spade isn’t correct. The CHT sensor is a female spade and the harness side connector / insulator is only a single spade. If I recall correctly (?? Questionable) the wiring harness side is a male spade that gets crimped to the harness and the the spade is inserted/locked into the plastic insulator. Yes, you are correct - I have a harness from Jeff and I went and looked more closely today - the connector he supplies is pretty opaque so it's hard to see what's inside, but after shining a strong light at it, it does indeed look like a male to female. Mine is a '73 so the female end going into it is actually the 270 ohm resistor, then I have a male to male coupling connecting that to the CHT female spade. |
| JeffBowlsby |
Feb 23 2026, 01:28 PM
Artie tells me his car is a very nice original so I have sent him an excellent condition original housing, it is nicely aged and translucent.
Lo-Fi Version | Time is now: 23rd February 2026 - 11:30 PM |
