| flxzcat |
Feb 18 2026, 07:30 PM
Member ![]() ![]() Group: Members Posts: 97 Joined: 13-June 11 From: Lake Forest, So. Cal. Member No.: 13,188 Region Association: Southern California |
Guys I need (#6) part #914.424.343.02 which is a large white plastic washer shifter slide plate thingy that goes between the reverse/1st slide plate (#2) and the shift lever compression spring (#7) in the shifter console. They used to come in three thicknesses 1.6, 2.3 and 3.4mm. My broken part is 1.6 thick, but I think I can make do with any thickness.
If I had a lathe, I'd make one out of Delrin in about 5 minutes. Let me know whatcha got. PM or text is best Thanks in advance, Paul VDL |
Lo-Fi Version | Time is now: 18th February 2026 - 11:05 PM |
