> Cooling Fan Balance Questions
aggiezig
post Feb 18 2026, 11:56 AM
Porsche Wannabe
Does anyone happen know how the cooling fans were balanced from the factory?
I took mine apart to refinish (Cerakote!) and very stupidly did not make any index marks for the front "ring" and back fan. I noticed on reassembly that there is a weight crimped under the ring lip, presumably for balance. I'm wondering if these pieces were balanced independently (unlikely) or as a unit...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.1.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.2.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.3.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.4.jpeg)
Any ideas from 914world on how I may find the right orientation / re-balance? My local machine shop said no dice as far as fitting it on any of their machines (ID of the fan shroud bore is too small).
post Feb 18 2026, 12:34 PM
I'd bet the assembly was balanced, have you sent the crank for balancing?
Jack Standz
post Feb 18 2026, 02:26 PM
QUOTE(aggiezig @ Feb 19 2026, 12:56 AM) *
Don’t know what those last couple sentences mean.
It’s a very good idea to balance everything in your motor that rotates. Flywheel, crankshaft, rods, pistons/rings/pins, etc. That means get that fan balanced. Have seen pictures of an exploded fan and it’s not something you’ll enjoy. Dynamic balance all of it and if your shop can’t or won’t do it, send to someone who can (DPR?).
mgphoto
post Feb 18 2026, 04:34 PM
If you took the fan apart and didn’t assemble it the exact same way then you have to rebalance the fan, I would include the hub, crank and the rest of the rotating assembly.
post Feb 18 2026, 05:09 PM
In addition to balance the ring has to be centered on the fan or it will rub the shroud.
Test fit it and see if it clears. If not loosen the bolts and teap the ring until you have equal clearance on all sides
TRP
post Feb 18 2026, 05:20 PM
Oh man, I was going to do the same thing with my fan (Cerakote), but I wanted to figure out how to make sure it was indexed the right way afterwards. In the end I kind of looked at it and said "it'll be fine all dirty".
I did notice that my fan doesn't have any of the timing marks on it, that seems like it's going to be a problem.
post Feb 18 2026, 05:25 PM
QUOTE(bdstone914 @ Feb 18 2026, 06:09 PM) *
changing the relationship between the hub (fan) and the pulley will affect the balance. It's possible everything will be fine, but it's a gamble. Yes, the clearance must be equal
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th February 2026 - 11:04 PM
