| Cvrguy |
Feb 15 2026, 07:06 PM
Newbie ![]() Group: Members Posts: 21 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
Just pulled mine out of my '73 today as I'm replacing the suspension bushings. Both bars are slightly abraded due to the very old bushings deforming (old? I hardly had to heat the retainers in order to get them off!). Replace or not? Mine measure a little over 18mm at the shaft (18.01 and 18.25mm to be precise. The difference may be in the amount of paint on the bars). I've checked the usual sources but no luck as yet. Who might carry them? I really don't want to increase the spring rate with the 20mm ones from Pelican.
If I clean these up, are they useable? Can they be reversed? Does the minor abrasion significantly change the spring rate? Are those from the early 911 of that era an alternative? While i'm at it, one of the adjuster screws shows signs of starting to split. Replace? |
| Cvrguy |
Feb 15 2026, 07:08 PM
Feb 15 2026, 07:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,768 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Replace
Damage like that to torsion bars creates stress risers. Bar will eventually break at an inconvenient time. Same on the bad adjuster screw which is already showing major cracks. You need new LCA bushings or you’ll just damage the new bars. Highly recommend Elephant Racing for new rubber bushings. They are sized properly. Many other suppliers parts aren’t. You can source the torsion bars via Elephant Racing. Note: it looks like Sway A Way has been through some changes recently with acquisitions, moving production to Mexico, and rebranding to X-sway. I would try to get older Sway A Way parts that someone like Elephant or Sierra Madre may have in stock vs being the guinea pig for the new products from X-sway until we know more about all the changes and how that may be affecting parts quality. |
| jim_hoyland |
Feb 15 2026, 07:40 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,042 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Where are those bushings located ? Doesn’t ring a bell….,,
Feb 15 2026, 07:55 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,588 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
As superhawk said you need to buy new or really good used. Those 18 mm or 914-4 size.
You’re not supposed to reverse left to right. |
| bkrantz |
Feb 15 2026, 07:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,647 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
| barefoot |
Feb 16 2026, 10:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Where are those bushings located ? Doesn’t ring a bell….,, At the rear end of the pivot tubes on the A-arms that contain the torsion bars. A very common wear item The rear A arm bushings carry almost all the weight of the front end so the bushings collapse over time to the point that the torsion bars start rubbing inside the housings. I've polished out the gouges to remove the stress risers and repainted the bars. It's lasted me 3 yrs now. Barefoot |
| Cvrguy |
Feb 16 2026, 11:18 AM
Where are those bushings located ? Doesn’t ring a bell….,, At the rear end of the pivot tubes on the A-arms that contain the torsion bars. A very common wear item The rear A arm bushings carry almost all the weight of the front end so the bushings collapse over time to the point that the torsion bars start rubbing inside the housings. I've polished out the gouges to remove the stress risers and repainted the bars. It's lasted me 3 yrs now. Barefoot Thanks to all. I have the new rubber bushings in hand. Just waiting for the LCAs to come back from sandblasting. I'll be replacing the torsion bars for sure. The jacking cones on the right side are somewhat deformed along with that adjuster screw. The ride height was equal both sides and there is no noticeable damage to the floorpan or the side rails. That's enough for me to not trust the right torsion bar at this point. The search begins... |
| jim_hoyland |
Feb 16 2026, 04:28 PM
| Cvrguy |
Feb 17 2026, 04:14 PM
Where are those bushings located ? Doesn’t ring a bell….,, At the rear end of the pivot tubes on the A-arms that contain the torsion bars. I don’t recall ever seen any; picture or part number ? Got a nice pair of used 18mm bars yesterday from Einmalig in Huntington Beach. I have a couple of cans of 2K chassis spray paint on the way from Eastwood as well. Should have it all back together by Monday. Do I paint the metal surfaces that come into contact with the rubber bushing surfaces? |
| Cvrguy |
Feb 17 2026, 04:16 PM
Feb 17 2026, 04:38 PM
The torsion bars do not touch anything (other than at the splines) unless the bushings are worn out in which case the LCA starts rubbing on the torsion bars.
Assuming the used bars you have are in good shape - just coat the bar with a light coat of grease to prevent future corrosion of the torsion bars. Corrosion, gouges, or removing the heat treated outer casing of the torsion bars will of course drastically shorten their life. Paint in addition to the OEM paint coating isn’t necessary. |
| bajafreaks |
Feb 17 2026, 04:49 PM
Member ![]() ![]() Group: Members Posts: 128 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
What is the deciding factor on when to replace the torsion bars? Looking at the pics from the original post they dont look too bad. I didnt realize they were so critical of a component.
Feb 17 2026, 05:31 PM
What is the deciding factor on when to replace the torsion bars? Looking at the pics from the original post they dont look too bad. I didnt realize they were so critical of a component. Torsion bars are a highly stressed spring where the outer heat treated layer is where the highest stress is concentrated. The center of a torsion bar does virtually nothing which is why you can have hollow torsion bars. When the outer hardened layer is compromised by corrosion, scratches, or gouging it creates a very localized stress riser where cracking will begin. Eventually the crack will propagate through the bar and the bar will fail catastrophically. This isn’t speculation. It is an engineering reality. Having a bar fail will ruin your day. Typical failure: ![]() The bars in the 1st picture are scrap. |
| Cvrguy |
Feb 20 2026, 12:28 PM
What is the deciding factor on when to replace the torsion bars? Looking at the pics from the original post they dont look too bad. I didnt realize they were so critical of a component. Torsion bars are a highly stressed spring where the outer heat treated layer is where the highest stress is concentrated. The center of a torsion bar does virtually nothing which is why you can have hollow torsion bars. When the outer hardened layer is compromised by corrosion, scratches, or gouging it creates a very localized stress riser where cracking will begin. Eventually the crack will propagate through the bar and the bar will fail catastrophically. This isn’t speculation. It is an engineering reality. Having a bar fail will ruin your day. Typical failure: ![]() The bars in the 1st picture are scrap. After cleaning up the replacement torsion bars, I had the LCAs and other bits sandblasted to prepare for painting. When attempted a trial fitting into the adjuster end, They don't fit! Was there a change in the number of teeth on the torsion bars over the model years? The original bars fit fine. ??? |
| 914werke |
Feb 20 2026, 12:50 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Feb 20 2026, 01:26 PM
When attempted a trial fitting into the adjuster end, They don't fit! Was there a change in the number of teeth on the torsion bars over the model years? The original bars fit fine. ??? The /6 & 911 Use a different spline bar Yep. If you have 911 torsion bars, they are 1mm larger and one more spline (iirc). Definitely won’t interchange with the 4’s. All 914-4 years used the same bar. |
| Cvrguy |
Feb 20 2026, 03:09 PM
When attempted a trial fitting into the adjuster end, They don't fit! Was there a change in the number of teeth on the torsion bars over the model years? The original bars fit fine. ??? The /6 & 911 Use a different spline bar Yep. If you have 911 torsion bars, they are 1mm larger and one more spline (iirc). Definitely won’t interchange with the 4’s. All 914-4 years used the same bar. Apparently the 914 bars are stamped with a "VW" on one end as well. |
Feb 20 2026, 03:10 PM
When attempted a trial fitting into the adjuster end, They don't fit! Was there a change in the number of teeth on the torsion bars over the model years? The original bars fit fine. ??? The /6 & 911 Use a different spline bar Yep. If you have 911 torsion bars, they are 1mm larger and one more spline (iirc). Definitely won’t interchange with the 4’s. All 914-4 years used the same bar. Apparently the 914 bars are stamped with a "VW" on one end as well. Makes sense since the 914-4 was assembled by VW and the six by Porsche. |
| Cvrguy |
Feb 21 2026, 11:09 AM
Lo-Fi Version | Time is now: 4th April 2026 - 08:12 AM |
