| Geezer914 |
Feb 11 2026, 04:41 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,217 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Anyone using mouse repellent pouches to repell mice from chewing the wires? I just lost power steering in my 2015 Ford Fusion. A mouse chewed through a wire going to the electric power steering rack.
| mmichalik |
Feb 11 2026, 05:06 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 788 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
Anyone using mouse repellent pouches to repell mice from chewing the wires? I just lost power steering in my 2015 Ford Fusion. A mouse chewed through a wire going to the electric power steering rack. I've been using this, so far it seems to be effective: https://www.amazon.com/Fresh-Cab-Botanical-...B00L236OMW?th=1 and it actually smells kind of good as well. |
| dtmehall |
Feb 11 2026, 05:46 PM
Member ![]() ![]() Group: Members Posts: 240 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
I ave read that mothballs are a good repellent. I ordered these, and they are scented.
https://www.amazon.com/dp/B077H5J4QJ?ref=pp..._fed_asin_title |
| Ninja |
Feb 11 2026, 06:12 PM
Member ![]() ![]() Group: Members Posts: 130 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Dryer sheets are supposed to work too.
One of my customer's had his insurance cancelled after the third vehicle was totaled via rodents and found the hands down winner for EVERYTHING repellant. Moth balls in socks or women's nylons hanging at all 4 corners. Nothing gets close to it. But if you drop your car off at a repair shop, tell them to park it outside overnight... He didn't, I parked it inside and the next morning I had to let the shop "breath" for 15 minutes to get the smell out. You can NEVER park it inside again but nothing alive will intentionally enter your vehicle. |
Feb 11 2026, 06:17 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,430 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
My daughter deals with it in Brooklyn NY. Mice, rats, everything. We’ve had to fix the wires on her Honda 3x. Honda uses a soy based cover on the wires so it’s particularly susceptible.
Two things we do. Honda sells an anti rodent tape to wrap exposed wires. It’s pricey but known to be effective. We spray a small squirt of pepper spray behind each wheel well. Doesn’t take much. Repeat every month. We also do the pepper spray on my wife’s Honda since the squirrels on campus are particularly aggressive and chew the oil lines. I also hit her parking spot with the spray from time to time. It’s been very effective so far. |
| campbellcj |
Feb 11 2026, 06:19 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,697 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Supposedly strong minty or citrusy things help, like Irish Spring soap or strong lemon air fresheners. I live in a wildlife corridor area, lots of critters, and nothing I have ever tried has worked other than physical barriers and traps. Have successfully kept the garage sealed for last couple years but it takes vigilance. I had significant wiring damage on my 997 previously. Rodents can squeeze thru the tiniest openings or chew their own. So, definitely patch up any openings and maybe lay some snap traps down.
| Ninja |
Feb 11 2026, 06:32 PM
Rodents make nests on the top of cabin air filters.
Most cars don't have a screen over the firewall opening. The opening is big enough for squirrels and small opossums. They then nibble on the cabin air filter, weakening it. The customer turns on the blower, it sucks the entire family into the squirrel cage, centrifugal force kills them and drains the "juices" into the blower housing and evaporator core. I charge MORE if I'm retching during the repair process! I add screens when I pull a dash. |
| TRP |
Feb 11 2026, 07:09 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
We went through this with my daughters 2024 Honda Accord... 8K in damage to the wiring harness. State Farm paid for the first one (after our deductible). Honda paid for the second one after it happened the again the day after we got it back.
We had originally asked Honda to wrap the wires in their OWN mouse repellant tape and they said "It's not worth the effort..." -- The second time it happened they offered to pay for it AND wrap the wires. No issues since then. I also put several pouches of moth balls around the motor bay and sprayed everything with that mouse repellant spray. We also put one of those sonic boxes in the engine compartment. Not sure what finally drove them away. The Tape The Spray The sonic box The crazy part is that we park our 2025 Cayenne S, 2020 Toyota Tacoma, and 2013 Toyota Tacoma all right next to my daughter's Honda. The rat/mouse/squirrel only eats her wires. (IMG:style_emoticons/default/WTF.gif) |
| bkrantz |
Feb 11 2026, 08:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,594 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
This?
| Highland |
Feb 11 2026, 08:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Tried sprays, pest sound generators, and daylight bulbs for a car in car port. The car is daily driven and we are not rural.
Only thing that works is leaving the engine hood open overnight; at least it has worked for the last month. Current car is a Bolt EV. Previous car was a 2005 Prius which got heavily infested. Some say because of the environmentally friendly starched based plastics. |
Lo-Fi Version | Time is now: 11th February 2026 - 09:14 PM |
